Old 02-26-2008, 05:59 PM   #661
Car: UGM 07 STI
Fav Mod: Learning to drive better
Send a message via AIM to Urban07STI
Default Re: Rear Strut Clunk Log
Mine just started to clunk......07 with just over 11K miles. Probably headed to the dealer soon to get it taken care of.
Urban07STI is offline   Reply With Quote
Old 03-13-2008, 08:00 AM   #662
Car: wrb 2005 STi
Fav Mod: FP GREEN
Send a message via AIM to blueman05
anyone have pics of this underneather i dont wanna grease the wrong thing... is it necc to remove the rear wheels to do this? i have white lithium grease not spray im sure that will work??
blueman05 is offline   Reply With Quote
Old 03-13-2008, 08:09 AM   #663
Car: 05 wrx sti
2005 wrx sti; 68000 miles 95% highway driving.
replacing rear struts and rear sway bar links
Symptons: clunk clunk
Cost out of my pocket: $1030 for both struts including labor and $140 rear sway bar
marksti2005 is offline   Reply With Quote
Old 03-13-2008, 08:10 AM   #664
Car: wrb 2005 STi
Fav Mod: FP GREEN
Old 03-13-2008, 08:11 AM   #665
Car: 05 Subaru WRX STi
You don't grease from underneath the car. No wheel removal necessary. You have to jack the back of the care up, slide the dust boot that goes over the rear struts up, and grease up the shiny strut shaft. Your strut is the tubular thing that's inside the coil springs.
rasetsu is offline   Reply With Quote
Old 03-13-2008, 01:53 PM   #666
Car: wrb 2005 STi
Fav Mod: FP GREEN
gotcha... just grease both rear ones. did have the liquid spray so i had to apply it with my hand. only could go up so far on it....
Old 03-13-2008, 02:06 PM   #667
I use Mobil 1 synthetic grease in a can so I smear it on with latex gloves. When the suspension moves up and down, it will distribute the grease.
Old 03-18-2008, 02:05 PM   #668
Car: Silver 05 STi
Fav Mod: Stage 2
Is it severely detrimental and unsafe to drive on? My passenger rear is the culprit...Will other parts be damaged in the process?
Misanthrope789 is offline   Reply With Quote
Old 03-18-2008, 06:34 PM   #669
Car: White 93 EG8
Send a message via AIM to EBTurbo
There is nothing wrong. nothing is broken or damaged. all is ok. there is just a clunking noise from the rear of the vehicle.
EB Turbo
EBTurbo is offline   Reply With Quote
Old 03-19-2008, 03:31 PM   #670
Car: ITS URABUS
Fav Mod: Pagids
Originally Posted by andyman8662 View Post
yeah carpenters
HeHe,i could build a house out of my trunk.
2slow2curious is offline   Reply With Quote
Old 03-19-2008, 08:54 PM   #671
Car: CGM 05
Fav Mod: IAG 38mm EWG
Send a message via AIM to 1loudsti
add me too....2005 with 29k....bought it used i dont know if they are OE struts in the rear....has it been firmly established that the only TRUE fix for this is coilovers?
1loudsti is offline   Reply With Quote
Old 03-20-2008, 11:05 AM   #672
Car: Silver 05 STi
Fav Mod: Stage 2
What is the source of failure on these clunky struts ?( I have clunk too)
Is it internal in the valving?
Old 03-22-2008, 09:28 PM   #673
Car: 05 STi CGM Stg2
Ok I only got to pg9 on this thread. I think I have the clunk but let me explain. I have Group N mounts
Prodrive Springs
Perrin links & Swaybars
GT Spec Lateral link brace
GT SPec Trunk Cage kit
Ti STi Front strut bar
Race ALK's
Roll Center Adjustment kit
14mm camber bolts in rear struts
Stock front camber bolts + 14mm camber bolts for the second bolt (all 4 are camber bolts)
TiC fender braces
Cusco Type1 under arm bar
Steering rack bushings
Now all this is very difficult to reproduce.
1) When I come to a stop sometimes the rear left strut feels like it just released a little more with a sort of pop (not a pop sound, kinda like a vaccum release...i could relate this to when finishing up the humpty dumpty with the lady )
2) When I back up the driveway and go over this slight bump (sometimes) there sounds like a rattle)
I am in Toronto area has anyone had luck with getting an 05 STi fixxed under warranty...do I have the clunk?
DOES THIS MEAN I CAN HAVE CATASTROPHIC FALIURE??
For ref this how the trunk cage looks like
Old 03-23-2008, 08:34 AM   #674
If in doubt, flat out
Trader Rating: (23)
It has to do with the inherent strut design but it is also because an insufficient amount of grease is used on the the rear struts from the factory.
I pulled my stock struts apart with 1k miles on them. There was very little grease in them and the vein (can't think of what else to call it. it's the indention that runs all the way around the inside top of the strut sleeve that is supposed to be full of grease) had only smudges of grease. There were globs of grease that had been heated to the point that they were hard in consistency almost cooked. I had no clunking problems, yet. I cleaned and then properly repacked the struts with synthetic grease.
I only ran the stock struts for an additional 3k miles with cobb springs followed by sti/arai springs before going with ohlins fixed perch struts to better match the sti/arai spring rates. my car doesn't get a lot of mileage aside from track days and autoxs but inspecting them during spring swaps for that short time showed no abnormal wear and no grease consumption.
Old 03-23-2008, 04:03 PM   #675
Is this a catastrophic failure or what? I need to know if this is noise vs failure of my strut. If its just a annoyance I can live with it but i dont want a failure. I'll appreciate being pointed in the correct direction.
