Old 06-17-2007, 11:00 AM   #616
Car: 06 STI UGM
Fav Mod: (o)(o)
Default Re: Rear Strut Clunk Log
Originally Posted by KruxSTi
Joined the strut clunk club. 22k miles on my 06. Took it to the stealership and mentioned the clunk while they were changing my oil. When I went to pay the service writer told me my new struts will be in next week... Sweet!
How lound was the sound?
jaydow11 is offline   Reply With Quote
Old 06-17-2007, 11:06 AM   #617
Car: 2005 STi, 2002 R6, 2
Took mine in on Saturday, told them about the problem and they acted like they've never heard of such a problem, but they agreed they would fix it under warranty. Surprisingly they had the rear struts in stock and all the parts required for the overhaul almost like they we're waiting for the next STi to pull in with a rear clunk. Pfffft. Shocker.
-Yamaha Dave
Yamaha Dave is offline   Reply With Quote
Old 06-18-2007, 11:43 AM   #618
Car: 06 STI UGM
Fav Mod: (o)(o)
So has Subaru actually fixed the problem with the Struts or do they just replace them with another set of the same?
Seems kind of pointless if they just swap the struts that will eventually have the same problem....
Thanks,
Jay
Old 07-06-2007, 06:49 PM   #619
I have the same problem on my 2005 sti(rear clunk). I took it to the dealership and they said they would'nt cover this under warranty due to the fact I lowered my car.
I would hate to raise the car back up so they will replace them. Does anyone have any other ideas not looking forward to buying coilovers either.
Also has this problem happen to anyone that has not lowered there car?
c ya evo is offline   Reply With Quote
Old 07-06-2007, 06:56 PM   #620
Ive got 20,000 miles on mine don't worry it will get alot louder. I don't even want to drive my car it's embarrassing. Sounds like the cars going to fall apart.
Old 07-10-2007, 01:43 PM   #621
RSV2/BF2142 Player
Fav Mod: Fixing Subie Rattles :)
Send a message via AIM to SiCkSTi04
lol same here dude my car hit 53k and now started the dang clunking sounds. i'm going to gease the hell out of the rears when i get it back from the shop
SiCkSTi04 is offline   Reply With Quote
Old 07-15-2007, 12:37 AM   #622
For those of you who used grease, how long has it been and has the noise come back? I read a lot of posts saying you guys sprayed or lubed it up and will let us know how long it'll last, but have not read many follow ups. Is this a almost permanent fix?
SubaruSTiMike is online now   Reply With Quote
Old 07-20-2007, 07:54 AM   #623
Car: 2005 Subaru STi
Fav Mod: Cobb Swaybars and Kartboy Endlinks
For all of you that got the struts replaced under warranty the first time... the clunk will come back, only it will come back when you're not in warranty anymore. Speaking from experience here. It appears they just replace the struts with the same garbage that will clunk again after awhile.
Now I just turn the radio up a bit.
krees23 is offline   Reply With Quote
Old 07-27-2007, 03:29 PM   #624
Car: JBP 04 WRX STi
Just lubed mine with lithium aerosol grease, worked like a champ. Took about 1 minute a side. We'll see how long it lasts.
drfrink24 is offline   Reply With Quote
Old 07-27-2007, 10:35 PM   #625
Car: 03 WRX STI
How do i go about lubing the strurs,do i have to remove anything or take anything apart,thanks
AUSI MUZ is offline   Reply With Quote
Old 07-28-2007, 05:52 AM   #626
Car: JBP 04 WRX STi
Jack the car up (obviously on the side(s) with the problem), pull up the dust cover thats inside of the spring, exposing the base and lower half of the strut. A tip to make it easier: You can use your cars lug nut wrench to hold the dust cover out of your way by sliding it thru the spring, and under the dust cover to hold it above the area you're working on.
Clean the grime and sand/salt off where the strut moves into the strut housing (the base), and then apply grease to lower (maybe 1 inch) of the strut shaft (the shiny metal part).
Go for a ride and confirm that your car no longer sounds like a 1983 Chrysler K-Car.
Old 07-28-2007, 07:40 PM   #627
Car: 05 Subaru WRX STi
I lubed my struts with Mobil 1 Synthetic grease about 5000 miles ago and it came back so I lubed them again and it's gone again. I think the fronts may actually be clunking too so I just lubed all four corners for safe measure since I have a jack and stands now after moving to a house.
rasetsu is offline   Reply With Quote
Old 08-01-2007, 11:37 PM   #628
Car: '04 WRC Blue Pearl S
Fav Mod: Nokian WR's, then RSi's, Bridgestone Potenza RE-01R's
Send a message via AIM to skeeler Send a message via MSN to skeeler Send a message via Yahoo to skeeler
I still don't understand why anyone bothers to lube their own struts. I am at 122,000 miles and have all four struts replaced under parts warranty every 20,000 miles. It's done in one day and I save $1135!
skeeler is offline   Reply With Quote
Old 08-02-2007, 05:41 AM   #629
Because the dealer isn't just down the street from me with the struts in stock and every time I leave my car with someone else, that increases the chances of it getting messed up. I can jack up the car and lube the struts at my own leisure in under 10 minutes.
Old 08-04-2007, 11:01 PM   #630
Originally Posted by rasetsu
Because the dealer isn't just down the street...
I understand your point and identify with it. I have at my disposal, a dealership at 25 or clear up to 120 miles and anywhere in between and I choose to go to the one 120 miles away. That's only because I receive from them, the best service.
