Old 08-04-2006, 07:42 AM   #481
Moderator
Car: 05 Ram 3500 CTD
Fav Mod: Majin
dropped my car off last night, hopefully I will hear something in the next couple hours..
Old 08-05-2006, 01:25 PM   #482
Moderator
Fav Mod: Majin
Strut ordered, no hassle. Another +1 for the dealership I go to. These guys have consistently taken care of any problems I have ever had...
Old 08-05-2006, 08:13 PM   #483
Car: 2005 Subaru STi
Fav Mod: Cobb Swaybars and Kartboy Endlinks
Originally Posted by krees23
Mine were clunking and rattling - I took my STi into a dealership and they replaced for free. Both the rear ones were leaking. FYI the part numbers on the new ones for a 2005 STi are:
Strut CP R R (20360FE900)
Strut CP R L (20360FE910)
Wow, it didn't take long but the clunk is coming back even with the new shocks. The new ones lasted about 20K miles before the rattling and clunking noises started again.
I think they just keep replacing them with the same defective parts until your car goes out of warranty, then your stuck.
krees23 is offline   Reply With Quote
Old 08-06-2006, 12:52 AM   #484
Moderator
Fav Mod: Majin
I wonder if SOA is aware of this thread...
Old 08-06-2006, 03:29 AM   #485
wdb
dances with roads
Inverted struts are prone to 'clunk'-ing. Putting new inverted struts in does not change that fact. Buy some white grease and smile every time you use it, thinking about all the strength and rigidity you're gaining and the unsprung weight you're saving.
Old 08-07-2006, 10:56 AM   #486
Moderator
Fav Mod: Majin
When mine started clunking there was an obvious problem as I could move the problem corner of the car by ~1" and it would stay where I put it until I moved it back. Will the grease trick fix that?
Old 08-10-2006, 04:56 PM   #487
Default add me
Another one to the list. I have a 05 STI with about 36,200 miles on it. I have been noticing the clunk sound for awhile now and finally read this thread. Did the little bouncy on the rear door sill and got the noise. Will definitely try the grease and see if it helps.
freeze is offline   Reply With Quote
Old 08-12-2006, 06:41 PM   #488
is this thing on?
Car: 05 STI - WRB on Gold
Once again I'm a member. I think the first time was around 20,000 miles. I'm currently at 35,000 miles and the clunk has returned. I have aabout 1,000 miles lef ton my warranty. But the dealer said they woudln't replace the struts again since I'm on aftermarket spring and group n tops. I figure I'll try greasing them and see what happens. Coilovers may or may not be in my very near future.
silverbetty is offline   Reply With Quote
Old 08-15-2006, 10:47 AM   #489
Moderator
Fav Mod: Majin
car is in the shop as I type this, got t3h f@$7@r outback wagon for loaner
Old 08-16-2006, 05:29 PM   #490
Car: 06 Subaru WRX STi
Fav Mod: My right foot...
Will the dealer replace the strut if they see a rear swaybar with aftermarket endlinks?
pantag is offline   Reply With Quote
Old 08-16-2006, 05:34 PM   #491
Fav Mod: Suspension
Send a message via MSN to Sunfighter
I noticed mine clunking at about 17,000 miles. Had the car at the dealership yesterday and they mentioned the outstanding bullitin. I mentioned that this is a common problem and they were working with SOA (I am in Canada with a US car) to get approval for the parts. Clunking is getting worse with time... and is now an exaggerated creaking sound from the rear end as well.
Sunfighter is offline   Reply With Quote
Old 08-16-2006, 05:35 PM   #492
Car: Steel Grey 06 STI
Fav Mod: Stage 2
subaru replaced both my rear struts at 15,000 miles
aznboi320 is offline   Reply With Quote
Old 08-16-2006, 07:25 PM   #493
I think I am about to join this club. I have noticed that when I go over bumps in the road, I hear a thunk in the back of the car. I knew this was a problem. I opened my trunk and pressed down on the car. Started hearing a clunk. Guess I will call my dealer in the morning.
DILLIGAFRacing is offline   Reply With Quote
Old 08-17-2006, 05:43 AM   #494
Moderator
Fav Mod: Majin
Do I look like I give a ****? sorry, common expression in my field of work... the easiest way for me to tell when my strut was bad was to try to lift the car on the corner that was clunking, I got over an inch of travel without trying too hard...
<TABLE class=tborder cellSpacing=1 cellPadding=6 width="100%" align=center border=0><TBODY><TR title="Post 815911" vAlign=top><TD class=alt1 align=middle width=125>pantag</TD><TD class=alt2>Will the dealer replace the strut if they see a rear swaybar with aftermarket endlinks?</TD></TR></TBODY></TABLE>
Most likely they will give you a hard time about the aftermarket parts, but some dealerships dont say anything. A lot of times they will turn their head if you put the stock parts back on. The only way to know for sure is to ask...
Old 08-18-2006, 08:06 AM   #495
Add another one to the list:
2005 STI w/14,800 miles - (purchased in October 2004)
Rear passenger side strut being replaced next week (along with my sometimes "chirping" stock alarm mechanism)
Grunt is offline   Reply With Quote
