Old 03-02-2006, 01:13 PM   #406
A.X.D.
Car: 2004 STi
Old 03-02-2006, 05:17 PM   #407
Car: '06 Volvo V70R
Fav Mod: Frontal Lobotomy
^^ aarrrrgh!! It's related to strut clunk... I had that something fierce as well as the turning clunk that Burns described.
Originally Posted by BurnsWRC
so essentially its small clank clank clanks....while ure turning slowly...and when u sort of pick up speed or straighten out the wheels it goes?
Yep. It was very noticable during actions such as tight turns to get into parking spaces. During straight slow-speed driving, no noise unless going over bumps, which would cause the 'normal' clunk, and also when stopping/starting as noted above.
Get it to the dealer and get them to replace your struts. I'll bet that takes care of the turning clunks for 'ya.
gargleblaster is offline   Reply With Quote
Old 03-03-2006, 05:59 AM   #408
Car: 04 Infiniti G35 Coup
Fav Mod: still antifreeze
Send a message via Yahoo to BurnsWRC
wooohooooo, i hope ure right gargle...... you're describing everything im going through and u seem to be the first person thats had exact same issue. So all you did was replace ure struts and everything went quiet?
man if i get this fixed ill be in subaru joyland, its the only thing that leaves a spike in my fun everytime i drive the car.
BurnsWRC is offline   Reply With Quote
Old 03-03-2006, 06:16 AM   #409
Fav Mod: ohlins w/RCE springs, sz55
Send a message via Skype™ to elirentz
I had the clunking in the rear bad. JUst go the struts replaced undr warranty and the car feels and sounds so much better. I can't believe I hadn't even realized how bad the car was handling until it got back to normal again. Hopefully these struts will last me for awhile
elirentz is offline   Reply With Quote
Old 03-03-2006, 03:50 PM   #410
Car: 2005 Subaru STi
Fav Mod: Cobb Swaybars and Kartboy Endlinks
Mine were clunking and rattling - I took my STi into a dealership and they replaced for free. Both the rear ones were leaking. FYI the part numbers on the new ones for a 2005 STi are:
Strut CP R R (20360FE900)
Strut CP R L (20360FE910)
krees23 is offline   Reply With Quote
Old 03-06-2006, 06:00 PM   #411
Default Rear strut clunk...I know, I know...
SO ,I just passed the ol' 9K mark and am starting to hear a fairly audible chirp coming from the pass rear area - more of a chirp than a clunk. I've actually heard it off and on since maybe 5K.
Anyway, my question is...What kind of grease should I buy to lube up the strut? Could someone recommend an actual brand and type as opposed to "lube or lithium grease." And maybe a place to buy it? NAPA? Wally?
Thanks!
BTW, my spanky new COBB bars have helped increase this lovely chirp noise since I put 'em on 2 weeks ago.
Brahmzy is offline   Reply With Quote
Old 03-06-2006, 07:50 PM   #412
my 05 sti has 16k mile and i hear something in the trunk but thers nothing in there is that the strut??
carlos is offline   Reply With Quote
Old 03-06-2006, 08:13 PM   #413
Fav Mod: GT-35R
when it gets bad enough go to heuberger and talk to mark higenbothem (sp) he replaced mine at 36k. he has an sti and is well aware of this problem.
cnstman is offline   Reply With Quote
Old 03-06-2006, 08:15 PM   #414
I'm around 15k miles, and out of nowhere i'm experiencing the rear stut clunk. Originally i thought something was not secured in the trunk, but it's certainily not the issue. I'm hoping the dealer will take care of me.
Old 03-06-2006, 08:46 PM   #415
Thanks!
White lithium grease and NAPA will have it. BTW, you need to take apart and lube the Cobb bar bushings on a semi-annual basis as well - the grease fittings don't work for ****. Hit everything while it's up on a lift: it'll take you or the mechanic about 10 minutes to do it all.
Old 03-07-2006, 05:54 AM   #416
Car: 2oo5 cgm STi
one of the clunk posts recommended Mobil 1 synthetic grease, I got some at Autozone; Walmart did not have it when I looked.
Old 03-07-2006, 06:31 AM   #417
A.X.D.
Car: 2004 STi
this thread is here for a reason. take some time and read through it before posting please.
Old 03-07-2006, 06:44 AM   #418
The truth is you can use whatever grease you want. There's no magic to this and you have to continue doing it anyway.
Old 03-07-2006, 07:01 AM   #419
What about replacement struts through the dealership? This clunking noise came out of nowhere after 15k miles on my car... i might mention it to the dealer when i get my 14 dollar oil change through them
Old 03-07-2006, 08:01 AM   #420
Fav Mod: Not working in the Summers!
Will he replace even if you have aftermarket springs?
RUGBY is offline   Reply With Quote
