Old 06-23-2008, 04:49 PM   #1
Car: Blue 07 WRX STI
Fav Mod: Soap
Default Engine Coolant - in a pickle
I drained my engine coolant. I retightened the drain plug. I applied the conditioner to the filler tank. I filled the filler tank with coolant to the brim. I did not fill any other caps (radiator cap and other one over engine).
What do I do now or what am I doing wrong? Any help would be appreciated. The manual is speaking greek to me.
STI Sibb is offline   Reply With Quote
Old 06-23-2008, 05:33 PM   #2
Car: 04/08STI 95SVX 86E30
Trader Rating: (53)
Default Re: Engine Coolant - in a pickle
Fill the radiator first from the cap on the radiator. When that is full, put the cap on and continue filling it from the resevoir. Start the car and let it idle until it has come up to operating temp and the fans have kicked on. Watch the coolant level in the resevoir and add coolant as necessary. put the cap on when the coolant stops going down.
That's it
Old 06-23-2008, 05:44 PM   #3
Fav Mod: Soap
That's it
I think I overcomplicated this. Terminology kills me lol. I actually dumped the conditioner into the reservoir tank instead of the filler tank.
The filler tank it speaks of has the tabbed cap.
The reservoir has the yellow plastic cap.
The radiator has the round cap.
Old 06-23-2008, 07:00 PM   #4
Fav Mod: Soap
Last question...
When draining old coolant through the drain plug, the operator manual says to then drain the reservoir tank. Does this happen through the drain plug, or do you need to pull the tank out and dump it manually?
Old 06-28-2008, 03:30 PM   #5
Car: 06 sti
Originally Posted by STI Sibb View Post
Last question...
i want to know as well.
also if i poured a coolent flush into the radiator cap and not the filler cap is that ok and is it still ganna be fully effective?
edit: also if i got a coolent that the guy at kragen recomended is that ok? do i need the conditioner?
bhp808 is offline   Reply With Quote
Old 06-28-2008, 03:41 PM   #6
Car: 98 Eclipse
Send a message via AIM to MaStA Send a message via MSN to MaStA
Last question...
The reservoir tank isn't going to get drained through the radiator. You will have to pull that out to dump it.
MaStA is offline   Reply With Quote
Old 06-30-2008, 04:20 AM   #7
Fav Mod: Soap
Try this. I figured out my problems and made a writeup to assist others.
DIY Engine Coolant Change
Old 07-11-2008, 08:12 PM   #8
Car: 05 WRB STi
Fav Mod: The car
Send a message via AIM to B00stedreams
Thats a great write up
B00stedreams is offline   Reply With Quote
