Old 06-17-2008, 06:49 AM   #1
Swollen Member
Car: 2004 PSM STi
Fav Mod: Dead hooker in the trunk.
Default 2004 STi 60k mile service how to.
My 2004 STi is coming up on 60k miles pretty soon, and I was wondering if anyone can provide me some resources on what needs to be done, and how to do it. I'm pretty sure I can take care of most of it. Just trying to save some cash....Thanks!
ToeKutter is online now   Reply With Quote
Old 06-17-2008, 07:16 AM   #2
Car: 06 WRB STI
Fav Mod: 22k complete reconstruction
Send a message via AIM to ///M Power
Default Re: 2004 STi 60k mile service how to.
If you have the manual it tells you everything that you need to have done at the 6k service interval.
As far as I can think of:
New Plugs
Center and Front Differential fluid
Rear Differential Fluid
I think replace the belt
Oil change
Change Air filter
......I know I am missing a few other things
///M Power is offline   Reply With Quote
Old 06-17-2008, 07:25 AM   #3
STI Guru
Fav Mod: grip.
got this from subaru for my car, it cant be much different for urs
MAINTENANCE DETAILS
Vehicle: 2005 IMPREZA WRX STi
Interval: 60000 miles / 60 month service
Action Description
Inspect Drive belt(s) [Except camshaft]
Inspect Camshaft drive belt
Replace Engine oil
Replace Engine oil filter
Perform Replace engine coolant and inspect cooling system, hoses and connections
Recommended Performance Replace fuel filter and inspect fuel system, hoses and connections
Replace Air cleaner element
Replace Spark plugs
Inspect Transmission/Differential (Front & Rear) lubricants (Gear oil)
Inspect Automatic transmission fluid
Replace Brake fluid
Inspect Disc brake pads and discs, front and rear axle boots and axle shaft joint portions
Inspect Brake linings and drums
Perform Inspect brake lines and check operation of parking and service brake system
Inspect Clutch operation
Inspect Steering and suspension
Recommended Inspection Front and rear wheel bearing lubricant
Perform Rotate and Inspect Tires
The above services should be performed at the mileage / time intervals indicated. To keep your vehicle running its best and ensure the continued safe operation of your Subaru, your dealer may also recommend additional inspections and services. Please contact your dealer for a list of these services.
Old 06-17-2008, 07:47 AM   #4
Car: 06 WRB STI
MAINTENANCE DETAILS
Action Description
Replace Engine oil
Replace Spark plugs
Replace Brake fluid
There it is
Old 06-17-2008, 07:49 AM   #5
Swollen Member
Car: 2004 PSM STi
Sweet! Thanks guys, you rock! Now I'm going to be spawning all these threads on how to do each of these items...haha! j/k
Old 07-10-2008, 12:44 PM   #6
NIИja
04 Maintenance schedule: http://img360.imageshack.us/img360/545/60566305om5.jpg
Old 07-11-2008, 09:24 AM   #7
Car: '04 WRB STi
Fav Mod: Bushings! TIC, FTW
Official Subaru link listing maintenance SUBARU.COM : OWNERS : SCHEDULES: include/2004myfed.html
19-Kilo is offline   Reply With Quote
