Old 05-16-2008, 05:41 AM   #1
Car: BLUE 05 STI
Fav Mod: HELLA FOG LIGHTS
Default How Fast Can You Shift Sti Transmission Without Grinding On An Undamaged Trans
JUST BOUGHT an sti 05 stock 45000 miles and the trans mission is totally differnt than an trans i have driven "older gc8 5 speed trans" gc8 trans you can shift in like a milasecond my new sti trans if i shift like that it will grind. under hard acelleration 1st to 2nd i have to wait like a 1/4 or half a second befor it will go in and 2nd to 3rd the same with all gears and also in 3rd some times a clunk or a vibration if i am under hard acceleration,and iF try to put it in too fast . and also i have to shift with like 2 to 3 fingers pressure light pressure and this is with the clutch to the floor . and also i was wonder ing where does a new clutch engade on. my sti it starts to engadge last inch and a 1/2. I'm also a very noligable on cars I'm a bmw tech. also if these problems are a problem will the dealer waranty and fixx whats wrong with the trans even if the guy beform me might have beaten on the trans and posibly grinded the sincrows
ONE LAST THING I CAN ONLY GO IN 1ST IF STOPED OR LIKE 1 MPH
leggman86 is offline   Reply With Quote
Old 05-16-2008, 05:52 AM   #2
Car: 05 subaru WRX STi
Fav Mod: Full-Race FTW!
Send a message via AIM to jnorth85 Send a message via MSN to jnorth85
Default Re: How Fast Can You Shift Sti Transmission Without Grinding On An Undamaged Trans
all of these things are somewhat "normal" your clutch issue is also normal.
i have a new clutch with 10k on it and it engages in the same place.
jnorth85 is offline   Reply With Quote
Old 05-16-2008, 06:10 AM   #3
Car: 05 WRB STi
Fav Mod: PWT Points
the sti is not very forgiving when it comes to downshifting. You can't put it in first unless you are practically stopped or just barely rolling - so don't be worried about that.
Old 05-17-2008, 05:31 PM   #4
How fast it goes into gear on upshifts is entirely dependent on the RPM I shift at. Properly driven, I have no difficulty shifting fast enough to bounce the rear diff against the car .
So true. And by far the most annoying thing about this car IMO. I wish Subaru would put a better synchro on 1st.
Old 05-22-2008, 07:08 AM   #5
Car: 07 STI LTD #67
Fav Mod: Andrewtech built, Turbo XS tuned GT35R 624 AWHP. 528 AWTQ on VP C16
If you want to get into first, there are two simple tricks, either rev the engine a bit so you can go into first, or if you are coming to a stop, press in the clutch, and move the shifter into 2nd then into 1st before letting the clutch out.
As far as the speed to shift gears, you just need to get used to it. I have problems sometimes getting locked out of gears and having to press the clutch back in and try the gear again when I am racing and FFS. It just takes some practice.
TAPOUT is offline   Reply With Quote
Old 05-22-2008, 09:58 AM   #6
Car: 06 Subaru WRX STi
Fav Mod: Valentine 1
Send a message via AIM to shan mann
Oh thank god i though i was the only person who had a problem with 1st gear lol
shan mann is offline   Reply With Quote
Old 05-22-2008, 10:00 AM   #7
Fav Mod: UR GT35r
Send a message via AIM to fractur3
this probably isnt good but i usually just force it in (and yes that is what she said )
fractur3 is offline   Reply With Quote
Old 05-22-2008, 10:24 AM   #8
i eat cones
Fav Mod: 18x8
Trader Rating: (21)
hahahaha ^
