Go Back   IWSTI.com: Subaru WRX STI Forums > Owners' Lounge > Warranty / Service Issues
Old 03-12-2008, 12:56 AM   #1
Car: UGM 07 WRX STi Ltd
IWSTI Addict since: Feb 2008
Default 2007 STi Limited Hesitation
So I have a 2007 STi Limited. What can I do to fix the problem without voiding the warranty or endangering the life of the vehicle?
LtdPilot is offline   Reply With Quote
Old 03-12-2008, 01:00 AM   #2
Car: OBP 05 STI protuned
Fav Mod: My sunroof!
IWSTI Addict since: Apr 2007
Default Re: 2007 STi Limited Hesitation
ok... well give us some detail as to what is the problem with your car, and then maybe we can point you in the right direction.
subi4justin is offline   Reply With Quote
Old 03-12-2008, 05:04 AM   #3
Moderator
IWSTI Addict since: Jun 2007
Have you gotten the SOA reflash yet? If not, it is worth a try. Otherwise, there really isn't anything you can do that won't technically void the warranty. I also have an 07 and had the same problems. I went with the Cobb AP, Stage 1. If I am concerned about the dealer knowing, I will reflash back to stock when I bring it in. There are other options out there for EM, for me though, the AP was the easiest.
Their current map does a pretty good job of dealing with the 07 issues, but it doesn't 100% eliminate them. Rumor has it there is an update in the works. From my experience and what I have seen from numerous others in here, it has been a HUGE help.
Old 03-12-2008, 06:04 AM   #4
Nonproductive
Car: 06 WRB STI
Fav Mod: 22k complete reconstruction
IWSTI Addict since: Mar 2006
Send a message via AIM to ///M Power
Well said and sums it up
///M Power is offline   Reply With Quote
Old 03-16-2008, 03:14 PM   #5
Car: Black 07 Subaru WRX
IWSTI Addict since: Nov 2007
Is there a website that we can go to and check our vin number to see if the reflash has been done to our car?
RACERX-USA is offline   Reply With Quote
Old 03-16-2008, 03:57 PM   #6
Car: 08 AW STI BBS/Nav
Fav Mod: Cobb stage 1 93 v2
Good luck with that! You just have to trust your stealerships tech's to verify if you indeed have the most current flash. IMO, just go out and by a Cobb AP and flash to stage 1 V1.04. Don't screw around and drive your car with the factory ECU map because over and over again it has been proven that it's a piece of sh*t, and will most likely lead to a not so happy engine in the long run.
josefmd is online now   Reply With Quote
Old 03-16-2008, 03:59 PM   #7
Moderator
Thanks!
Not that I know of. You'll have to talk to your dealer.
1.04 has been released? Checking on that now...
Old 03-16-2008, 04:00 PM   #8
FYI, the latest Cobb map V1.04 is out and it is a improvement over 1.03
Old 03-17-2008, 06:19 AM   #9
Moderator
Have it loaded on my AP now! I'll have to wait until later today to install. Since this is a new map, you run the "Change Map" option, correct?
Again, I should have time to datalog, let me know what you guys want to see.
Old 09-21-2008, 12:36 PM   #10
Car: Limited 07 Sti
Fav Mod: bel rx65.....K BAND
IWSTI Addict since: May 2008
yeah i went stage one and i still have hesitation, if not worse than before..... i think my car is just really messed up! since my turbo cant make over 12 pounds and i only get 208 whp....
STi Guru is offline   Reply With Quote
