Old 03-04-2008, 05:41 PM   #1
Young and restless
Car: 2005 Aspen White STI
Fav Mod: Torque
Send a message via AIM to MikeO Send a message via MSN to MikeO
Default Strut Knock on the 05' -- Subaru Warranty Repair?
Hey all,
So i've decided to take my car in for a full service before i leave on vacation for spring break. It is much over due as all i have changed since the cross country drive was my oil.
On top of that, i have a lot of strut knock going on from both my rear struts and i was thinking to myself yesterday "why not have subaru fix the problem for me while it's in the shop for a service."
With that thought also came questions of A. Does my warranty (that i think i still have for another 2-3 months) cover that problem. and B. If not, how much would it cost for them to fix (and would it be a long term fix)?
If anyone has a "simple" answer to my question that would be awesome.
Essentially i am just weighing if it is worth my money to have Subaru fix it versus just jacking up the car and spending a few hours cleaning and greasing them (i found a DIY thread on here by someone a bit ago).
Thanks for any and all info guys!
MikeO is offline   Reply With Quote
Old 03-04-2008, 07:16 PM   #2
Car: '05 CGM STi
Default Re: Strut Knock on the 05' -- Subaru Warranty Repair?
If your under the 3yr/36k mi mark then yes it is covered.
Old 03-04-2008, 07:19 PM   #3
Car: 04 sti
Fav Mod: enginuity tuned
mine was covered under the extended warranty.
Old 03-04-2008, 07:27 PM   #4
Young and restless
Fav Mod: Torque
Yeah i only have 27k miles, but the car is going on 3 years of purchase now. I'm not sure how much time i have left... guess i need to figure that out.
Anyone know how much it might cost me to have them replaced if not through the warranty?
Old 03-04-2008, 07:46 PM   #5
Photography Mod
probably an arm and a leg...one rear taillight is $175 if that gives you an idea of their markup.
Old 03-04-2008, 10:06 PM   #6
Young and restless
Fav Mod: Torque
well that is unacceptable, guess if i'm off my warranty i'll be doing it myself.
Old 03-05-2008, 12:34 AM   #7
Car: '04 WRC Blue Pearl S
Fav Mod: Nokian WR's, then RSi's, Bridgestone Potenza RE-01R's
Send a message via AIM to skeeler Send a message via MSN to skeeler Send a message via Yahoo to skeeler
I have an '04. I have had all four struts replaced under warranty and just got the car back to the dealership for having the rear struts replaced again. I believe this is the sixth replacement of both rear struts and only twice for the fronts. The fronts are also shot and since the dealership is not finding a failure from having their techs look at it, I will be communicating with SOA. Bottom line, if it is failure, it is in your best interest to take it up with your local/preferred dealership. At least if it is still under warranty when you take it there and they decline the claim, you can come back a little bit later with a legitimate complaint and will likely have your replacement.
Depending on your warranty/extended warranty, you may be subject to a deductible. But having a pair of struts replaced at no cost is a savings of almost $600 or more.
skeeler is offline   Reply With Quote
Old 03-05-2008, 11:33 AM   #8
Young and restless
Fav Mod: Torque
Thanks Skeeler. I'll be happy if i can get the rears replaced for now. Although last night in the cold the fronts sounded like they were "creaking" which kind of scared me a bit. They might just have a lot of dirt/dust in them though... i know they creaked after a few occasions of dirt fun and went away after i sprayed the wheel wells.
Old 03-05-2008, 11:50 AM   #9
Car: Silver 07 Legacy
PM me your last 8 of your vin and I can find out for ya.
If it is within 3/36k they will fix it. If not and you do not have an SAS plan, you may be out of luck.
Old 03-05-2008, 09:19 PM   #10
Young and restless
Fav Mod: Torque
Thanks for the offer blackfang, i actually just called today to schedule the car for my 30k maintenance and they looked up my VIN and what not. My 3 years expires on May 23rd so i have some time left. They're going to have the service manager look at the struts with my advice of "a strong strut knock in the rear." Hopefully he thinks they are banged up enough to replace them.
This is probably a stupid question to ask... but what are the odds they will just replace them for me instead of go the absolute cheap route? The struts knock 100% consistently every time i drive (that's how bad it has gotten now). I'm assuming it depends on the service guy and the dealership eh....
Guess i'll be finding out in the next two weeks.
Old 03-05-2008, 09:50 PM   #11
Car: White 93 EG8
Send a message via AIM to EBTurbo
I think rear struts and mounts cost over a $1000 plus labor which will probably be in the $400-500 range. your best bet for a permanent fix would be replacing the suspension with an after market coil-over. the problem lies in the strut itself. so replacing it will not fix it. and technically the dealer is not allowed to replace them. no matter what warranty you have. if they replace them once they will have to replace them for life if they make the noise again within the parts warranty. and if they replace them a third time you can have them lemon the car.
EB Turbo
EBTurbo is offline   Reply With Quote
Old 03-06-2008, 03:19 AM   #12
The rear strut mount for both sides should be under 650 unless the dealer is raping you.
Old 03-06-2008, 03:20 AM   #13
Good to hear.
What is the cheap route? We replace the strut mounts if they are bad.
Old 03-06-2008, 03:22 AM   #14
hmm this is weird my 3 year 36k is over
49k orig service date= may 04
but when i took it in the guy at the desk had my car go on a lift and ordered me a new driver rear strut because it was leaking?
are they gonna get me with some hidden charge when i pick the car up he claimed that it was fully covered by my warranty and it would be no cost to me?
is there any way i can get the other shock replaced as well?
garamas is offline   Reply With Quote
Old 03-06-2008, 04:15 AM   #15
Do you have an SAS Gold policy? If not, then that strut is not covered. You are beyond the 3 years or 36,000 miles.
You need to clarify with them how much it is going to cost before you sign that repair order.
