Old 02-15-2008, 08:36 AM   #1
Default Engine Revving when i stop??
I've recently been having an issue where when i clutch and come to a stop, the engine revs on it's own up to about 2100 and holds for a few seconds before calming down. It's been doing it for a couple months, i took it in to Subaru but of course they said nothing was wrong and sometimes they just "do that". I've had the car 4 years and it's never just "done that" until recently so i'm trying to figure out what could be wrong...any suggestions of what i could look into or at least hound them to look into? Thanks.
Tang is offline   Reply With Quote
Old 02-15-2008, 08:48 AM   #2
Car: Blue 07 STI
Send a message via Yahoo to brantdw
Default Re: Engine Revving when i stop??
I live in the Portland area. Took a vacation to Yellowstone last fall. The altitude change was +8000 ft. When I was in Yellowstone when I would disengage the clutch it would rev and extra 500rpm and then come back down. At sea level the RPM's would just drop the instant the clutch was pushed in. I'm not sure if this is a related problem. Sound to me like an air meterering problem or a computer issue.
brantdw is offline   Reply With Quote
Old 02-15-2008, 09:28 AM   #3
Black Dragon STI
Car: 07 OBP STi 03WRB WRX
Fav Mod: My whole suspension
These cars will rev a bit when the clutch is pushed in due to some emissions thing. I can't remember if it's to keep the cats hotter, or to burn the extra richness you get when the throttle plate slams closed.
Old 02-15-2008, 09:31 AM   #4
Car: 07 OBP STI
is it the same revs as when you engage the clutch for a shift?? cause then thats just normal i believe
Old 02-15-2008, 09:46 AM   #5
Car: 03 Subaru WRX
Fav Mod: Angry Pig...
Send a message via AIM to Garo666 Send a message via Skype™ to Garo666
My car does this exact same thing if im in traffic or in a drive through ... lol pretty annoying cause mine dosnt just calm down after a few seconds ... mine usually takes like 10 min just to settle back to normal...
My shop told me it was the throttle body area... the two lines one for the actually gas pedal and the other for the cruise control. what happens is the cable gets stuck, causing the engine to rev high, normally if you just drive around the cable goes back down. might want to check that out.
Garo666 is offline   Reply With Quote
Old 02-15-2008, 10:54 AM   #6
Hmm, i'll check that out about the cable.
Yeah what's odd about the whole issue is, it's never done this up until recently...if it had done it from the get-go i'd not question it, but since it's obviously different it makes me wonder... :/
Thanks for the responses, keep em coming and i'll update this as/if i find out more!
Old 02-15-2008, 11:08 AM   #7
If in doubt, flat out
Trader Rating: (23)
There's no cable. USDM STIs are drive by wire.
Old 02-15-2008, 11:08 AM   #8
Trader Rating: (23)
I've experienced this especially when the engine is hot.
Old 02-15-2008, 11:24 AM   #9
Black Dragon STI
Garo666 has a bugeye which has two cables. I've noticed the same behavour in my bugeye as my STI. I think the cruise control motor is used by the ECU for holding the revs between shifts, just like the TBW cars.
Either way, I hate it when the engineers try to second-guess my driving, or the EPA's requirements makes my car do thing I don't tell it to. Unfortunately, short of a standalone ECU, I don't think there's a fix.
Old 02-15-2008, 11:26 AM   #10
A.X.D.
Car: 2004 STi
not sure exactly, but it sounds like something is causing the ECU to adjust fuel trims to adjust so that it runs stoich at that particular load.
check that all your vacuum lines are connected properly.
Old 02-15-2008, 10:52 PM   #11
Car: 03 Subaru WRX
Lol im soo lost ...
Originally Posted by Carroll Smith in 'Tune to Win'
While full rotation [of a race car] about the yaw axis is not uncommon it is also not desired. Nothing good has ever been reported about the full rotation of a race car about either its pitch or roll axis.
Old 08-02-2008, 01:18 PM   #12
I totally forgot to update this when i got the problem fixed. Ended up switching out the spark plugs, and the issue went away instantly.. :/ Just thought i'd update you all!
Old 08-02-2008, 01:24 PM   #13
HPDE lover
Fav Mod: Pro-Tune!
Really? I might have to try that then. It's been happening to me for a couple months now to and it sucks. Especially when you pull up next to a police officer and you can't shut your car up!! Makes me roll the window down and tell the officer "sorry, my car has been doing that lately" lol, yeah it sucks.
Rewind is offline   Reply With Quote
Old 08-02-2008, 01:28 PM   #14
Car: 06 Aspen White STI
if anyone has a after market bov they may not be closeing all the way... or you have a vaccum leak some were... these probs are big with dsm eclipse and talons
but dnt quote me im just starting to learn about subies
sti4411 is offline   Reply With Quote
Old 08-02-2008, 02:17 PM   #15
Car: 08 WRX STI
Fav Mod: BLITZ Nur Spec DT
i experienced those, buts it was when i had my ECU changed (OrientWorks' Result Magic JDM) during a test run...
i decided not to get the new ECU at that point (no budget, yet), and had OrientWorks had to put back my old ECU... then my car started doing those revs at idle - it only lasted for a couple of days, it was normal from then on...
alfredjp is offline   Reply With Quote
