Old 01-29-2008, 12:14 AM   #1
Car: 05 white sti
Fav Mod: XSF36XXZ,XRR37XXZ,KLC39,KLC047
Default Snapped an axle
It just happened. Made a u-turn... and it just broke. I basically broke the front left.. I am still waiting for a word from SOA warranties because the dealer said this would not be covered under warranties. My car has only 26000 on it. Anybody else had similar problems?
koker is offline   Reply With Quote
Old 01-29-2008, 09:51 AM   #2
If in doubt, flat out
Trader Rating: (23)
Default Re: Snapped an axle
did they give a reason why they wouldn't cover it?
Old 01-29-2008, 10:01 AM   #3
Fav Mod: TBE
I bet they're assuming abuse and are waiting on an SOA rep to check it out. Just stand your ground but with the suspension work in your sig I bet they'll try to deny it.
Old 01-29-2008, 10:02 AM   #4
Car: 05 Aspen White STI
Fav Mod: Defi Gauges
Send a message via AIM to STI_Mike
but with those suspension MODs would that cause an axel to break?
STI_Mike is offline   Reply With Quote
Old 01-29-2008, 10:04 AM   #5
Fav Mod: TBE
No they're not really linked at all, but some stealerships will try to pull that crap. They have ways to tell if you've been abusing the car tho.
Old 01-29-2008, 10:13 AM   #6
Fav Mod: TBE
http://www.bescaredracing.com/sti/ts...axle_tsb_1.JPG
http://www.bescaredracing.com/sti/ts...axle_tsb_2.JPG
Those are the TSBs they will be using against you
Old 01-29-2008, 10:20 AM   #7
so basically if you don't drive your car like a grandma then ur screwed.
Old 01-29-2008, 12:21 PM   #8
If you want to push the issue, they have to prove that your modifications caused the damage.
With that said, if, while doing a Uturn you broke your left front, you broke the axle with the least force being applied to it. Something is missing.
That TSB is for rear axles.
Old 01-29-2008, 03:14 PM   #9
Car: Silver 07 Legacy
Just be courteous and professional with them and you will get farther. The moment you don't, it pisses the dealer and SOA off and more than likely they will be less likely to help you later on. There is a time to be nice and a time not to. The time not to is should be reserved for the end even after a few attempts have failed.
Old 01-29-2008, 03:23 PM   #10
Fav Mod: Carlabs X-brace & RPM brace
Just say f-it and get some gator axles or something and then don't worry about it. First axle that snaps on me and I'm changing all 4.
hoffit is offline   Reply With Quote
Old 01-31-2008, 08:35 PM   #11
Car: 05 white sti
Well they finally covered the repair, i just have to pay for the car rental. But The thing about it is that they wrote it in the comment that it was not a warranty coverage but a "goodwill" gesture from SOA and further noted that damages from abusive driving and or from modification. Oh well, but i have to address that and they have to prove it that it was due to abusive driving...
Old 01-31-2008, 10:37 PM   #12
Send a message via AIM to eze13sti
ya had all those mods and they warrantied it. niiiiiice.
eze13sti is offline   Reply With Quote
Old 02-01-2008, 03:59 AM   #13
They wrote that so it documents that it is a one time goodwill. So if you come back in with another one, you are paying for it. Sometimes things are not covered by warranty, but the dealer or SOA can goodwill repairs. All of my Goodwill's I mention that on the invoice.
