Old 10-12-2007, 05:52 PM   #1
Car: 05 STI - Cobb Stg 2
Fav Mod: Curb Feelers (driver side)
Default passed 36K warranty. what's next
is there a second warranty that is there for a Subaru? i know that the service (parts and labor) was covered up to 36k for things like brakes etc. but i also heard that there was another one that covered the car up to 50K for major things - like drive train etc.
can anyone confirm this.
Ras
RAS_STI is offline   Reply With Quote
Old 10-12-2007, 06:16 PM   #2
Car: 06 STI, 08 GSXR 750
Fav Mod: 8cm 20g
Default Re: passed 36K warranty. what's next
You can buy another warranty but I wouldn't recommend it since you're car is modified. Chances are if anything big ever goes they wont cover it
Hitman83 is offline   Reply With Quote
Old 10-12-2007, 09:46 PM   #3
yeah i know i can buy one. but isn't there two warranties standard? one that covers parts and labor for small things like brakes etc and another one that is more a larger coverage?
maybe not. but that's what i thought. i'll call the dealer tomorrow.
Old 10-12-2007, 09:49 PM   #4
Car: 06 WRB STI
Fav Mod: Maddad DP/Borla XR-1 Turboback
5 year/ 60,ooo mile powertrain warranty...
engine, transmission, driven axles...
minorthreats is offline   Reply With Quote
Old 10-13-2007, 12:50 AM   #5
Car: 07 STI OBP
Fav Mod: we will see soon...
so if you manage to screw up the clutch, or somehow snap 1st gear they would potentially cover it under 5year /60K miles if they dont declare abuse? in this case who needs the extended warranty
JustinH is offline   Reply With Quote
Old 10-13-2007, 04:37 PM   #6
thanks for the confirmation Minor.
Old 10-16-2007, 01:29 PM   #7
Car: Silver 07 Legacy
Clutch falls under the 3/36k.
Old 10-17-2007, 06:06 AM   #8
Fav Mod: The Newest One!
That's correct. Otherwise I think Minorthreats is correct on the 6/50k powertrain warranty. There should have been a warranty book that came with your car when you bought it. All in the info is in there.
Old 10-17-2007, 03:57 PM   #9
yeah...i bought the car used (19K). no books no nothing.
i'm calling sube with my VIN and see what they say. i update this thread with the answer.
thanks guys.
RAS
Old 10-17-2007, 03:59 PM   #10
RSV2/BF2142 Player
Fav Mod: Fixing Subie Rattles :)
Send a message via AIM to SiCkSTi04
SUBARU.COM : TOOLS : WARRANTIES FOR 2005
Rust Perforation Limited Warranty
Rust perforation coverage for all vehicles is five years regardless of mileage. Since all Subaru vehicles are built to resist corrosion, the use of additional rust-inhibiting materials is not necessary and is not a requirement for coverage under this warranty.
Powertrain Limited Warranty
Powertrain coverage for all models is five years or 60,000 miles, whichever comes first. It covers the major powertrain components listed below:*
Engine block and all internal parts
Cylinder heads and valve train
Oil pump, oil pan
Timing belts or gears and covers
Water pump
Flywheel
Intake manifold
Oil seals and gaskets
Turbocharger Assembly
Transaxle case and internal parts
Transaxle seals and gaskets
Axle shafts and constant velocity joints (except boots)**
Torque converter
Electronic transmission control unit
Propeller shaft
Wheel bearings
See your Subaru Dealer for complete details.
**Axle shaft and/or CVJ damage due to broken, torn, split or damaged boots, allowing the intrusion of road abrasive material, is not covered under warranty.
SiCkSTi04 is offline   Reply With Quote
Old 10-17-2007, 04:01 PM   #11
Sicksti04
Old 10-17-2007, 04:14 PM   #12
RSV2/BF2142 Player
^ no problem
Old 10-17-2007, 04:14 PM   #13
Car: Blue Slate 08 G37S
Fav Mod: TBA...
Send a message via AIM to VtecSTI Send a message via MSN to VtecSTI Send a message via Yahoo to VtecSTI
Sometimes more things are covered at a certain dealership. It all depends on who you know. I got my car towed from the track, to the dealership, and still got my axle replaced under warranty. I have coilovers, sticky/larger tires, and alot of other mods. I believe thats the only freebie i'm going to get though
VtecSTI is offline   Reply With Quote
