| | #16 | |
| Super Moderator Car: 08 DGM STI Fav Mod: My wife :) Location: Brooklin, Ontario Posts: 5,842
IWSTI Addict since: Oct 2003 Trader Rating: (0) | Quote:
Tires ultimately determine how much braking force you can apply but you still need brakes that can take maximum advantage of the tires capabilities. This ad is not endorsed by this member. Please register or login to hide this ad. | |
| | #18 | |
| Spec C Club Car: BMW M5 993 Turbo Location: Southwestern, CT Posts: 1,293
IWSTI Addict since: Sep 2005 Trader Rating: (5) | Quote:
As for your example give the same car weight, same tires and different rotors/caliper in a fade free situation the two cars would slow down nearly identically. The biggest factor in your example would be fade and doesn't exist in your example or on the street in this video. 2nd to fade would be the surface area of the brake pad and the compound of the pad. Assuming the pad compounds are equal we are left with surface area which is an unknown in your example, but even if the surface area was 10% smaller it wouldn't cause that noticable of a difference in stopping power/distance. If the surface area is the same, but the brembo car has larger rotors then the brembo car might take longer to stop given that the surface area is the same, but the rotor is larger and heavier. Bigger brakes do not mean smaller stopping distances. They act as a heat sink and prove their valve in track environment where heat from repeated heavy braking is an issue. On the street pad compound and pad/rotor surface area could make a small difference, but the two biggest factors on a street car's braking distance would be weight and tires, not brembo brakes. Using anything less tha a R compound tire on the street the average car will be able to trigger ABS with the stock brakes. If you can trigger ABS then you are under tired and over braked. | |
| | #19 | |
| Amateur STI Driver | Quote:
. I had no idea I'd hit a nerve in someone.: I know what the gumball is. I'm just ranting about the stunt they pulled in traffic and put the saftey of all others on line. It had nothing to do with how much I paid for my STi or how slow my car is. Relax. | |
| | #20 |
| Senior STI Driver | depending on where in Italy they were,there was likely no speed limit, can't say it was a stunt, it was probably driving too fast for conditions(traffic), but they made it another day due to IMO good reaction time, good brakes & tires. The truck driver's error, as was stated above. |
| | #28 | |
Typically with big brake kits you upgrade to bigger rotors along with the caliper. More surface area and a bigger rotor allows more leverage to be applied by the caliper/pad. A larger caliper can apply more friction to a given surface than can a smaller caliper (makes sense since the pad is restricted by the size of the caliper.) As long as you aren't overloading the tires, this is a good thing. My argument is that two cars, with different brake setups, decelerating from 130mph are going to have different rates of deceleration, up to a point. The car that can generate more friction/apply more leverage will decelerate faster because it can maximize tire grip usage. I would imagine most stock calipers/pads cannot overwhelm the tires at 130mph and I would hazard a guess that they also aren't maximizing the usage of the tires. Now, once the speed drops to 60-70mph, assuming constant braking force, I'm sure the two hypothetical cars would decelerate at similar rates, since the car with the bigger brakes would probably begin to overwhelm the tires as the speeds decrease. Furthermore, I'm not talking a drastic difference in braking distance. Perhaps only a 10-30ft (remember the speed we're braking from). But in a situation like this, at 130mph, that distance could make a big difference. A smaller caliper is going to apply less leverage than a larger caliper. At these speeds I think that will make a difference. Everything else you said is true though. To maximize stopping distances for a street car, I would focus on tires, then pads, front weight, and then a big brake kit (rotor/caliper.) For racing, I would go with a bigger brake kit to address heat dissipation (i.e. more consistent performance under heavy use), as you said. | |
| | #29 | |
Again the subject of this thread is claiming the brembo brakes are what saved the day in this video and I disagree. The tires did. Sure maybe the upgraded brakes helped a tiny bit over the stock M5 brakes, but this wasn't a track session with repeated braking on R compound tires. It was a street car with street tires making a single emergency stop and the tires played the biggest role in stopping the M5 in this video. | |
| | #30 |
| STI Driver | hahaha... hmmm look... without the brembo's braking capability the tires will be useless therefore they both play a role with each other... if you dont have good brakes your tires are useless, if you have good tires your brakes are useless, but if you have BOTH then they are both the reason for why the M5 was able to stop... so enough debate this was just for ammusment This ad is not endorsed by this member. Please register or login to hide this ad. |
