Go Back   IWSTI.com: Subaru WRX STI Forums > Owners' Lounge > Video Collection
Old 11-12-2007, 10:43 AM   #1
Fav Mod: Innovative Tuning
IWSTI Addict since: Jan 2006
Default Innovative Tuning Project Voltron at Dunville Autodrome (lapping day)
Here's a clockwise lap at Dunville Autodrome. This was on spring pressure (low 11 second boost). 245 tires just don't cut it on this car. I need to add flares and some big slicks to get more power down, but I think this is a good start. We also need to add an external oil cooler and some more ducting for the radiator and front brakes.
31 MB. 640X480 High Res. Requires QuickTime.
RIGHT CLICK>>>>SAVE AS:
http://www.innovativetuningdl.com/vi.../Session1B.mp4
OR
Youtube streaming (smaller, lower res):
Subie TV
Inn-Tune is offline   Reply With Quote
Old 11-12-2007, 04:03 PM   #2
Evil Monkay
Car: 06 Subaru WRX STi -
Fav Mod: Hydra
IWSTI Addict since: Oct 2006
Subie Love
Silver SEMA 2007 Sponsor
Send a message via AIM to bbong Send a message via MSN to bbong
Default Re: Innovative Tuning Project Voltron at Dunville Autodrome (lapping day)
The car sounds insane, and from looking at the video looks hella fast!!
bbong is offline   Reply With Quote
Old 11-12-2007, 04:12 PM   #3
IWSTI Addict since: Oct 2005
That very well could be the most steering I have ever seen... You must have a pretty obscene amount of power to require as many steering corrections as were performed on that lap. Like you said better rubber would most likely help. Thanks for posting!
dozer5 is offline   Reply With Quote
Old 11-12-2007, 04:16 PM   #4
Car: Gt35R STi
Fav Mod: JrTuned FTW Bro
IWSTI Addict since: Dec 2005
Send a message via AIM to boostedrex05
sick mike looks really fast. Do you have a Quick Rack yet? if not man you should get one you can see you have to turn the wheel a lot to get that beast to hit the corners.
also try a higher gear on that last turn and roll the throttle into boost I wanna go run at the track no
boostedrex05 is offline   Reply With Quote
Old 11-12-2007, 04:57 PM   #5
I gave several rides that day. Everyone twitched and grabbed for things constantly, but nobody said a word from the moment I got on it until I slowed for cool down. Then there were a lot of expletives, screams, giggles, and laughs. Then almost all of them asked me how I was so calm while driving it. It's a matter of constant correction even while going straight. I can't imagine driving an enduro with the existing rubber. It requires every ounce of concentration all the way around the track.
After 1/2 a warmup lap and 3-4 laps blasting around I was coming in since front brake, coolant, and oil temps were all getting rather hot, but I didn't mind because I was ready for a break.
I gave up on second gear aside from showing off and tried to stay away from third wherever possible. I can slow it down at 3000 rpm, but anywhere near 4000 rpm or higher it's hard to contain. It makes boost and torque so easily it's hard to ease on the power. I can make full boost at 1/4 to half throttle and as soon as it starts making boost, BAM you have all of it. On a higher speed course it won't be anywhere near as much of an issue, but Dunville is a slow and technical course for the most part. Third gear corners are just too slow.
I'm using a power rack without power steering and as it is the steering is VERY light while on power at all. With power steering you wouldn't feel anything as soon as you hit the gas and I need to feel which wheels are spinning and where the power is going as much as possible. Adding a quick rack wouldn't add to that, but it could make my corrections less subtle and it's hard enough to strike a balance between being smooth and fast. The only times I found myself turning the wheel excessively were to save it from looping when the back came around under heavy braking and corner exit...of course that happened a lot.
Old 11-12-2007, 06:10 PM   #6
Non-Reformed Meth Addict
Car: '06 WRB
IWSTI Addict since: Feb 2006
Sounds like a proper car should. Looks like an enjoyable handful.
Old 11-12-2007, 06:15 PM   #7
Car: 04 STI
Fav Mod: group n engine mounts
have you experimented with the dccd? I bet if you were to set it one down from lock it wouldn't oversteer so much on throttle.
brgwsti is offline   Reply With Quote
Old 11-13-2007, 07:59 AM   #8
I have full control over it thanks to a prototype interface for my Autronic box from DCCD Pro. I tried some different duty cycles on the diff, but I'm so far away from having traction that diff adjustment can't resolve the issue. Once I get closer to having grip I'll be spending a good deal of time tweaking the controller. Full lock, full rear power, and a spot somewhere in the middle all send me drifting if I power out of a corner.
Old 11-13-2007, 09:14 AM   #9
Car: Gt35R STi
Sounds like loads of fun man.. Maybe you can tune it down some for that track might be faster in some area but it won't be as fun
Old 11-13-2007, 04:11 PM   #10
Turbineguy I love that pic.
I did what I could. I took the boost controller off and ran spring pressure, but my spring pressure is 21 psi since I run 29-30 psi on the street and more at the strip. I had a mix of a little race gas from the strip and a lot of 91 pump in the tank so I had a conservative tune on it, but the car still makes mid 4XX whp like that...just not the 500+ I push normally.
Old 11-14-2007, 08:36 PM   #11
Car: '06 WRB
Old 11-15-2007, 06:31 PM   #12
Car: 07 OBP/Gold STi
Fav Mod: DomTune & MD Whisper
IWSTI Addict since: Jun 2007
wow... that looks like quite the handful. Scary fast
Loubaru is offline   Reply With Quote
