Go Back   IWSTI.com: Subaru WRX STI Forums > GD Series STi Discussion (2003/4-2007) > GD-Marketplace > Vendor Classifieds > Vendor Group Buys
Old 06-27-2007, 09:13 PM   #1
IWSTI Addict since: Aug 2003
Send a message via AIM to IA Performance
Default Aquamist HFS-5 Alcohol Injection system
As an authorized dealer we have been given the authorization to run a Group Buy on the totally new Aquamist HFS-5 shurflo injection systems. This is the end-all injection system in our opinion. Good to support vehicles from 250 wheel hp all the way over 700 wheel hp. We've installed cooling mist, snow and other similar systems. The one complaint/problem that we have is that those kits were incomplete 9 out of 10 times. Plus, the fasteners, fittings were no where near the quality of Aquamist. Rest assured, your install headaches will be greatly minimized with this unit.
52mm Gauge, Blue and Red are the bar graph color options.
Here is a run down on how the Group Buy will go.
* Mini Group Buys in increments of 5.
* 5% off list of each unit. $895 is list, you pay $850.25.
* Free shipping in the 48 states. We ship worldwide at additional shipping fees
* Group Buy #1 closes July 20th, if the first 5 spots are filled we will end it early and begin the 2nd 5 spots, so-on and so-forth
* Shipping time will take ~1 week depending on final Group Buy numbers reached.
* DDS gauge is offered in 2 colors (the bar graph is the only color part), you will have to denote Blue or REd upon check out. Blue looks the best against the amber dash.
* 100% deposit required to lock you in. NO DIBS, "dibs' does not mean squat.
* Items are instock in the US as of June 27, 2007.
1st Mini Buy ending July 20th:
1-
2-
3-
4-
5-
2nd Mini Buy ending Aug 5th:
1-
2-
3-
4-
5-
Included Pump items:
- Custom heavy-duty Shurflo pump with 125psi internal by-pass valves.
- 22cc surge arrestor and accumulator guarantees low pressure ripple operation.
- High speed PWM valve ensures accurate flow control against fuel duty cycle.
- Fast dynamic response time to LOAD and RPM transients (PWM mirrors IDC)
- Consistent droplet size due to high system pressure under all conditions.
- Powerful 150 Watt pump motor capable of maintaining flow beyond 2 liters per minute.
- DDS3 (bundled) ensures flow is monitored constantly for clogged jet or cut hose.
- 2x failsafe channels to perform advanced failsafe tasks such as boost cut, map switch, etc.
- Water and methanol compatible (0-100%)
- All hoses and tank fittings, fasteners, water level sensor electrical harness supplied
- 3x water jets: 0.8mm, 0.9mm and 1.0mm and one Y-piece.
- Water tank is not supplied, here is a nice option for Subaru and EVO owners (it can be made to fit the EVO very easily)
Additional Information found here:
http://www.iaperformance.com/product...oducts_id=2451
We accept the following payments:
- all major CCs
- Debit Visas
- Paypal
- wire transfers
Feel free to phone or Email me with any questions you have regarding this Group Buy.
Stephen
stephen@iaperformance.com
IA Performance is offline   Reply With Quote
Old 06-28-2007, 07:00 AM   #2
Car: 05 Subaru WRX STi
Fav Mod: Tein Flex coilovers
IWSTI Addict since: May 2007
Default Re: Aquamist HFS-5 Alcohol Injection system
I call dibs for second group buy I will most likely be purchasing this next month though!
FritoBandito is offline   Reply With Quote
Old 07-03-2007, 08:44 AM   #3
Car: WRB WRX STi 2004
IWSTI Addict since: Dec 2002
Water tank link not working...
STI 2004 is offline   Reply With Quote
Old 07-09-2007, 09:00 AM   #4
Car: 06 STi
Fav Mod: Powder Coated Rims
IWSTI Addict since: Dec 2006
Send a message via AIM to <-SubyDude->
oooo i want very bad but im wondering how bad it is to put in. or around how much to have someone else put it in
<-SubyDude-> is offline   Reply With Quote
HTML code is On
