| The Next Petter Solberg Car: 04 WRX Fav Mod: Turbo Upgrade Location: Cave Creek, Arizona Posts: 979
IWSTI Addict since: Jul 2005 Trader Rating: (4) | We are in the works with Cosworth to become a distributor of their products! To start dealing with them directly we need to place a large order so to do that we are looking for preorders on anything Cosworth. Pricing will be determined on how many items we get on our initial order. I promise it will be worth it! Cosworth celebrated its 45th year at the top of the world motorsport stage in 2003. During that time, Cosworth has established itself as the most successful engine manufacturer in Formula One as well as achieving numerous successes in CART, Indycars and the World Rally Championship. Please check out some of these amazing items please PM for pricing. Cosworth EJ25 (STI) short block New Subaru EJ25 STI Engine Case New Subaru STI Forged Crankshaft Cosworth Forged Connecting Rods Cosworth Forged Pistons Cosworth High Performance Piston Rings Cosworth Race Spec coated Tri- Metal Bearings Balanced and Professionally assembled Billet Crankshaft optional ![]() Subaru CNC Ported Big Valve Cylinder heads CNC Ported/machine finished ports - New OE Castings Hand blended finish work Intake 22% Increased Flow (max) Exhaust 41% Increased Flow (max) 4-angle Inlet Valve job 3-angle & radiused Exhaust Valve job Valves are lapped Back-Cut Inlet Valves Heads are Ultra Sonic cleaned prior to assembly Heads are Serialized and sport a machined Cosworth logo +1mm Stainless Steel Intake Valves (1800 degrees max.) +1mm Inconel Exhaust Valves (2400 degrees max.) Performance Valve Springs Titanium Retainers Hardened Steel Spring Platforms Knife Edge port divider Subaru EJ25 STI (2.5L) 79mm stroke billet crankshaft Increased engine performance often means increased engine speed and load. Original factory crankshafts may not be able to withstand the added stress resulting in catastrophic failure. Cosworth billet crankshafts are machined from ultra strong EN40B steel and are engineered to endure the harshest conditions and have been tested to withstand over 1000HP! Features include superior lubrication, profiled counterweights and added strength. ![]() Subaru EJ20/EJ25 High Performance Rod Bearing set Engine bearings are one of the most vital components within an engine and are often overlooked when considering high performance upgrades. Performance engineered, multi-layer bearings generate less heat than normal bearings by reducing friction. Cosworth Race bearing sets feature a unique combination of design, metallurgy and engineering to deliver what drivers expect from high performance Tri-Metal engine bearings. Engineered with the following features: •High strength overlay plate with reduced thickness for better oil control and less friction •Hardened steel backing on all connecting rod bearings •Increased crush and elimination of flash plating •3/4 grooving on Main Bearings providing optimum oil supply •Tight consistent wall tolerances •Oversize chamfers where applicable •Tested to over 1000 horsepower! Subaru EJ20/EJ25 Camshaft set Cosworth has been engineering camshafts for nearly 50 years. That coupled with years of innovative multi valve cylinder head design ensures our camshaft designs or the most efficient in providing maximum usable power across the widest power band. Each cam is ground from a new chill cast billet and finished using the same procedures we use in our extreme level race engines. Cosworth camshafts are the perfect compliment to our CNC Ported Big Valve Cylinder heads. Our Subaru EJ25 cams are profiled to increase boost response thereby increasing engine torque and power and are fully compatible with the Subaru STI AVCS. Please download the technical document on the left for camshaft specifications. Ground from new chill cast billets Price is for complete set of four Requires spring upgrade or high performance valve train Works well with big turbo ![]() Subaru EJ25/EJ20 Forged Piston Set The piston is one of the most important components within an engine. It can be subjected to directional change up to 285 times every second and must withstand acceleration forces up to 8500g. Cosworth high performance forged pistons are designed and engineered to withstand this type of punishment and still perform. All Cosworth forged pistons are manufactured using the same methods as our Formula One pistons and feature friction reducing skirt coating, ultra strong pins, polished tops and patented anti-detonation bands. Additionally, each application uses a unique forging to minimize weight and ensure the strongest possible piston design. • Proprietary Cosworth alloy • Popular sizes • Unique forging • Skirt coating • Polished top • Anti-detonation bands • High strength pin Subaru EJ20/EJ25 High Performance Cylinder head Stud Kit Essential for high performance engine builds, heavy duty head studs reduce cylinder head movement in high boost engines optimizing cylinder head to block sealing. Ultra high performance fasteners are manufactured from high tensile strength steel and come complete with nuts and washers. Subaru EJ20/EJ25 Billet Timing Belt guide Replaces the factory sheet metal timing belt guide to help reduce the possibility of the timing belt skipping a tooth during high rpm use. Precision machined from aluminum with a hard anodized finish. ![]() Subaru EJ20/25 Oil Pump Designed to improve the oiling on modified engines. Each pump is disassembled and inspected. Oil galleys are then honed to ensure unobstructed flow. We then incorporate a modified pressure relief valve to maintain pressure stability throughout the rpm range. Note: Flow rate is unchanged. This is an essential item on any high performance engine. Please call or PM for pricing! ~Jon 480 219 6652 This ad is not endorsed by this member. Please register or login to hide this ad. |
| | #8 |
IWSTI Addict since: Jul 2005 Trader Rating: (4) | Got it and pmed back! This ad is not endorsed by this member. Please register or login to hide this ad. |
| Thread Tools | |
