Go Back   IWSTI.com: Subaru STI Forums > STi Marketplace > Vendor Classifieds > Vendor Group Buys
Closed Thread
Old 04-17-2008, 02:15 PM   #46
Car: UGM 07 WRX
Default Re: TiC SST Coilover GB/Special savings
Ive read they work fine with Grp N tops, so i dunno why the stock ones would be any different?
on that note, Tony/Clint how will these go together with a set of PDE/DMS mounts ?
Rain is offline
Old 04-17-2008, 02:45 PM   #47
Fav Mod: TiC AST's - 7/6K
They have been great for me so far on group-n tophats. You shouldn't have any problems on the stockers as long as they are torqued properly.
Originally Posted by chron View Post
Hey guys,
Do you recommend I buy the camber plates at this time? I was reading elsewhere about problems sometimes with fitment on the stock top hats. I'm not really planning on autox'ing any time soon and I've already spent more money than I planned. I'd rather do this right though and buy the plates if it means making the install work properly.
4banger is offline
Old 04-17-2008, 02:50 PM   #48
Car: Aspen White 04 STI
Good to hear! Only reason I asked was I thought someone mentioned either in another thread here or on NASIOC about getting 14" drop in the rear and that'd be about it. I'm assuming the proper torque specs are included with the SSTs?
chron is offline
Old 04-17-2008, 02:57 PM   #49
Excellent insturctions are included. I have plenty of clearance at 14" in the rear, but you could run into rubbing issues if you try and go too low. Why you would want to go any lower and screw up the suspension geometry, I don't know. These coilovers are definately not made for slamming your car, they are made to ride and perform well.
4banger is offline
Old 04-17-2008, 03:26 PM   #50
I'm all down for good instructions. I'm definately not looking to slam my car. In fact I was planning at running stock height to start out. I just saw some ppl recommended 14" up front and 13.5 in the rear to begin with.
chron is offline
Old 04-17-2008, 03:39 PM   #51
Car: UGM 07 WRX
4banger ride hight wise (if you know) how are these compared to running the RCE yellows? just wondering
Rain is offline
Old 04-17-2008, 04:03 PM   #52
You know what, I had things backwards. I'm at 14" in the front and 13.5" in the rears.
4banger is offline
Old 04-17-2008, 04:14 PM   #53
Ya know... I think you're right 4 Banger. I think I got my ride heights reversed.
chron is offline
Old 04-17-2008, 04:21 PM   #54
I'm not sure what you you mean. You can vary the height of the TiCs and the RCE springs ( I have the bronze ones from the very first batch) have a set height. I wrote a review of the TiCs. Just look under the threads that I have started.
4banger is offline
Old 04-17-2008, 05:20 PM   #55
13.5" is definately ideal in the rear. I bet you were reading about someone with wider than stock tires.
4banger is offline
Old 04-17-2008, 05:35 PM   #56
Car: UGM 07 WRX
I mean comparing your ride hight now, with the RCE springs ( i have a bronze set also )
I had them on Koni strut inserts, and just found the drop perfect. but now my rear tires rub a little in the turns.
Lol i know you can change the ride hight of these i was jsut wondering compare to the recommended settings
but thanks either way!
Rain is offline
Old 04-17-2008, 05:37 PM   #57
The RCEs *seemed* a tiny bit lower, but I never measured the ride height with the RCEs
4banger is offline
Old 04-18-2008, 04:45 PM   #58
Hey 4 Banger,
How long did it take you to swap struts for the coilovers? My friend has a lift so I know that'll help speed things up but I've never done this before so how long should I expect?
chron is offline
Old 04-18-2008, 04:51 PM   #59
Hey 4 Banger,
It took me a while because I ran into some problems with my X-brace. If it wern't for that, I probably would have taken about 3 hours.
4banger is offline
Old 04-18-2008, 06:32 PM   #60
Car: UGM 07 WRX
I can swap from summer struts to winter struts in about that time too, ive done it maybe 4 times so once you memorize the torque settings on the bolts and all that its pretty fast, i think the worst part is lining up the rear top bolts one arm under the well the other making sure the bolts are in the right spot.
If you are unlucky enough to live in an area of bad winter salt/road chemicals, the struts to spindle bolts can be a bit hard to deal with. Air tools are amazing for that tho.
Rain is offline
Closed Thread
HTML code is On
