Go Back   IWSTI.com: Subaru STI Forums > STi Marketplace > Vendor Classifieds > Vendor Group Buys
Old 12-18-2007, 05:39 PM   #1
Trader Rating: (25)
Send a message via AIM to GarageSpec.com
Default JIC FLT TAR Coilover Inventory Blow out 04 sti 02+ wrx
Garage Spec have 2 sets of JIC FLT TAR Flag ship coilover in stock and need to go by this week.
Application : 04 sti / 02+ wrx GDA
Spring rate : 7kg/5kg
MSRP $2070
INVENTORY BLOW OUT PRICE $1550
SHIPPED !!! THIS WEEK ONLY.
25% OFF MSRP
Originally Posted by JIC Website
The JIC FLT-TAR is the flagship coilover system. All FLT-TAR coilovers are designed on US-spec vehicles for US streets, fitment and performance is unmatched. Included in the kits are pillow ball upper mounts with adjustable camber plates. For flexibility, the dampers have 15-way compression and rebound adjustability. The spring rates are of the linear-rate type with independent ride height adjustable lower brackets. This allows adjustment without compromising damper compression or rebound travel. Based off of racing technology, the FLT-TAR is a street performance suspension, customizable for full time track use. NOTE: some applications may come with a rubber bushing upper mount. A Pillow Ball upper mount may be substituted for additional cost and with no warranty. Please contact us for applications and details.
ADJUSTABLE DAMPENING
Available for all applications with 15 ways adjustability. With this feature, you are able to tune your suspension dampening up to your spec.
UPPER PILLOW BALL MOUNT
Included for some vehicles for the front and some for rear application. Adjustable camber plate also included for most vehicle front applications with Macpherson Strut suspension systems. Some applications may come with a rubber bushing uppermount.
COOL BEND LINEAR SPRING
Linear rate spring manufactured using chrome silicon metal alloy with cool bend process.
MONOTUBE NITROGEN GAS DAMPER
High pressure nitrogen gas filled monotube design with special stable viscosity index oil that will not be affected by wide temperature changes. Some applications come with inverted damper system which will give an extra durability to the suspension performance.
DURALUMIN 6061 SEATS
Made out of durable and light weight alloy, manufactured using machining process.
ADJUSTABLE HEIGHT LOWER BRACKET
More durable than factory brackets with adjustable ride height ranging from 0.5" to 2.5" drop without sacrificing the suspension travel.
40MM / 45MM PISTON
Within the dampers are either a 40mm or 45mm piston along with bump and rebound shims the degine the valving characteristics.
DUST BOOT COVER
The dust boot cover protects the shaft of the damper of any debre
Link to JIC MAGIC official Website
JIC Magic - FLT-TAR Series
GarageSpec.com is offline   Reply With Quote
Old 12-18-2007, 06:19 PM   #2
Trader Rating: (25)
Default Re: JIC FLT TAR Coilover Inventory Blow out 04 sti 02+ wrx
Phil from Element tuning runs JIC
Click below for story
JIC Magic - Contact
Old 12-19-2007, 07:16 AM   #3
Trader Rating: (25)
bump....
Old 12-19-2007, 10:42 AM   #4
Trader Rating: (25)
Also in stock
18x8.5 +45 5-114.3
1 set in stock
Color: Aluminite Black
MSRP each wheel: $338.00
Inventory blow out price $1030 SHIPPED!! That's $257.60 per wheel
Must be sold this week or they will be gone.
Old 12-19-2007, 01:56 PM   #5
Trader Rating: (25)
bump on these bad boys
Old 12-20-2007, 07:23 AM   #6
Trader Rating: (25)
bump...
HTML code is On
