Closed Thread
Old 09-22-2007, 07:10 AM   #1
AMS
Car: '05, '07 WRX STi
Fav Mod: BOOST!
IWSTI Addict since: Nov 2006
Send a message via AIM to AMS
Default AMS FP Green Test!
In the midst of our very chaotic move we were able to get my car on the dyno and finally test this bad little boy. The results were very nice and we are really impressed with the turbo. The car is now making 75 more WHP at Redline on pump gas!
On with the test
The Vehicle: 2007 Subaru Sti
Modifications:
AMS Custom Catback
Turbo XS Downpipe
AMS Test Pipe
AEM Cold Air Intake
Vibrant Header with up-pipe
Deatschwerks 850CC top feed injectors
Walrbo Fuel Pump
Forced Performance FPGreen with an 8cm turbine housing and 2.4" Inlet
Forced Performance High PSI internal wastegate actuator
STOCK TOP MOUNT INTERCOOLER
pump Gas
21 Psi tapering to 18psi
Mid to low 11's AFR's
The First graph here is just the numbers. Here is what she did last night on the dyno. we are pretty impressed!
Now here is that same graph in STD Correction for those that are used to using the "Standard" Correction factor
And last but not least here is the HP curve outlined over the tune with the stock tubro. All that was changed was the FPGreen and the fuel modifications to support it. Look at the HP increase at redline!!!
All in all we are very happy with the results and considering the spool time we will deffinetely be recomending this turbo to our subaru customers.
Next on the modification path is to try this same combination with our AMS Top Mount Intercooler, Remove the Tumbers, Try an FP 3" Cover and toss an External Wastegate actuator on it. Oh, and of course throw some real gas at it
We think with some better boost control and a little less heat soak we can squeeze close to 400whp out of this little bolt on turbo.
Eric Gaudi
Sales Manager
AMS Performance
AMS is offline
Old 09-22-2007, 09:09 AM   #2
IWSTI Addict since: Aug 2005
Send a message via MSN to RFFG
Default Re: AMS FP Green Test!
Nice work
RFFG is offline
Old 09-29-2007, 08:41 PM   #3
AMS
Fav Mod: BOOST!
track results were very good. the car went 11.75 @ 116.4 MPH today. The car still has an internal wastegate, Stock bov, Stock TMIC and a stock clutch.
I am going to try and fix the above and cut a 10 second pass
Eric
AMS is offline
Old 09-29-2007, 08:55 PM   #4
Car: 06 STi Spec C
Fav Mod: The STi experience
IWSTI Addict since: Oct 2006
AMS FTMFW! Nice to see you guys dabbling in Subie's now!
06SpecC is offline
Old 09-29-2007, 09:08 PM   #5
Fav Mod: Maddad Whisper
IWSTI Addict since: Dec 2006
Send a message via AIM to topend Send a message via Yahoo to topend
Very impressive.
topend is offline
Old 09-30-2007, 07:59 AM   #6
Muller Chevrolet
Fav Mod: a new 09 STi
IWSTI Addict since: Oct 2004
add some meth to the mix!
VSGTS14 is online now
Old 10-02-2007, 08:04 PM   #7
Car: 06 Aspen White w. Go
Fav Mod: teH Muff
IWSTI Addict since: Apr 2006
You guys are sick.
uncle lewie is online now
Old 10-03-2007, 04:43 AM   #8
Banned
Car: 2002 Civic LX
Fav Mod: 30+ MPG =]
IWSTI Addict since: Sep 2006
Send a message via AIM to STiSubyMan
Eric
oh wow!
thats impressive.
STiSubyMan is offline
Old 10-03-2007, 06:12 AM   #9
Car: 2003 Z06
That is a VERY impressive accomplishment with all those stock parts on the car. Keep up the great work!!
jgheels2003 is offline
Old 10-03-2007, 06:19 AM   #10
Fav Mod: 05 Tails, Protune
IWSTI Addict since: May 2005
Send a message via AIM to Pastapuck
Neat post, it's great to look at some hard numbers. I see an FP Green in my future
Pastapuck is offline
Closed Thread
