| | #91 |
| Authorized Vendor | Just as a side note - rear stroke on the ohlins sportlines (by hand pressure) is only 4.5 inches. No idea how far into the bump stop that took it though. This ad is not endorsed by this member. Please register or login to hide this ad. |
| | #92 | ||
| Amateur STI Driver | Quote:
| | #93 | |
It'll be interesting to see how your experiment works out. Do you have any gear for monitoring wheel position? Even a camcorder mounted on the side of the car pointing at a wheel can give you some useful feedback. (edit - changed 'foot-valve' to the more common 'base-valve') Last edited by DuncanG; 07-24-2007 at 01:43 PM. | |
| | #94 | |
| Silver Member
Car: Aspen 2005 STi Fav Mod: TurnInConcepts Coilovers Location: Silver Spring, MD Posts: 1,938
IWSTI Addict since: Mar 2006 Trader Rating: (2) | Quote:
The Penske manual, the only one I'm familiar with regarding damper construction, deals with needle (bleeder) valves and shim stacks (with variable preload). So, what's a "foot valve" and why would it help hysteresis? The only mention of it that I can find defines it as the bottom valve in a twin-tube damper, but we're discussing monotubes here. Edit: I found this on hysteresis reduction through pressure balancing: http://www.roehrigengineering.com/ca...0Balancing.pdf | |
| | #95 | |
| Authorized Vendor | Quote:
| | #96 |
| Amateur STI Driver | Yes but Penske don't say whether thats a typical or a bad example - maybe its not so bad, dunno ![]() The base-valve is not about reducing hysteresis but cavitation. The Roehrig article on pressure balancing gives some insight on that. Yes all twin-tubes have a base-valve and its making me wonder if thats a reason why in the budget market twin-tubes can be better. The simplest monotube arrangement consists of the rebound chamber, piston, compression chamber, floating piston then gas. Resistance to compression is provided by suction on the rebound side of the piston as obviously you cant create pressure on the compression side since thats coupled straight to the floating piston and gas. Too much compression -> too low a pressure in the rebound chamber and the fluid cavitates (in effect boils) so limiting compression. There's a good video of that on the Roehrig site. The next step up in quality provides a base-valve that is fixed in between the main piston and the floating piston. It provides some resistance to compression (but not extension, by means of a valve). Now in the compression stroke there is increased pressure in the compression chamber with less suction needed in the rebound chamber so cavitation can be reduced. Ohlins shocks for the S2000 and some QA1 socks are examples of this type. The base valve also means that a lower gas pressure can be used leading to a lower 'rod-force' on the shocks. The next step up again takes us to high-end shocks with the gas and floating piston in an external tank with adjustable valves. I don't have the definitive answers - just trying to shed some light on possible pitfalls and trying to work out why I found the ASTs so disappointing. Last edited by DuncanG; 08-04-2007 at 03:41 AM. |
| | #97 |
| Silver Member
IWSTI Addict since: Mar 2006 Trader Rating: (2) | Well, Dennis Grant has said 125psi is sufficient for eliminating cavitation in Bilsteins, which use a very similar design to AST (no head/foot valve) as far as I can tell. AST seems to be running much more gas pressure than that. A 22mm strut shaft would have a surface area of 0.59 square inches. At 100lbs of extension force from the strut, that'd imply a gas pressure of 170 pounds per square inch. |
| | #98 | |
| Amateur STI Driver | Hmm, I've used Bilsteins and they were fine - no hs-bump collapse. So I guess that theory is busted. <edit><edit>(edit...) Or is it? From another thread - Quote:
The fact that Dennis Grant doesn't have cavitation with 125psi at only 3inch/sec for his auto-X tuning doesn't mean much in the real world where I expect my shocks to work at 30+inch/sec. [edit] However the ASTs have a much bigger piston than the 40mm Bilsteins so that reduces the need for such a large pressure. The hi-speed bump softness I felt in the ASTs was probably just down to soft 'comfort' valving. </edit></edit> Last edited by DuncanG; 08-04-2007 at 03:45 AM. | |
| | #99 | |
| S204 Racer Car: RIP 02 WRX Fav Mod: 2004 Aspen White WRX STi Location: Cincinnati Posts: 3,614
IWSTI Addict since: Dec 2005 Trader Rating: (1) | Quote:
I'm high tech, damnit! | |
| | #101 | |
| Silver Member
IWSTI Addict since: Mar 2006 Trader Rating: (2) | TiC, see if you can source these tophats: http://www.vorshlag.com/images/catal...ne1_e46_01.jpg Quote:
Anyway, your dyno graph would have me believe the AST's have a little more than 100lbs of extension force, equating to ~200psi internally. That's in line with what I thought most monotubes ran at. (Edit: I see your spreadsheet uses 50kg, or ~110lbs and ~186psi) Last edited by stretch; 07-24-2007 at 12:23 PM. | |
| | #102 | |
| | #103 | |
| | #104 | |
| Silver Member
| | #105 |
| Amateur STI Driver | You mean the pink trace at 120N (27lb) or the blue on at -120N (-27lb)? No - thats the hysteresis, not the gas-force, as that has already been corrected for in the dyno-plot spreadsheet. This ad is not endorsed by this member. Please register or login to hide this ad. |
| Thread Tools | |
