Old 05-24-2006, 11:07 AM   #1
Car: Your STi ;)
Fav Mod: Everything
IWSTI Addict since: Mar 2005
Default 544.5 whp Cosworth Heads, 50/50 Water/Meth "low boost"
Well, it appears the Cosworth heads are well worth it
Other mods were:
FP Red, Perrin FMIC, Perrin Modded injectors, Snow kit with "some tweaks." Perrin BigMaf, WJM TGV deletes and a few other little things.
On 11 psi (staying under the meth spray) it made 330 whp.
At 22 psi it made 445 whp.
We were OUT of time so all we were shooting for was top end, to see where it went. With the AVC-R doing all the work (slow ramp to full boost), and NEVER spraying the FMIC, at 29 psi it made:
We had planned on going to 34 psi or so, but the manager here said that if I didn't have car outside the gate in 20 minutes they were locking us in...
We'll have it back on the dyno in a few weeks.
The torque is low because of the AVC-R settings. It wasn't making full boost until up top, but that was all we were playing with at the moment.
SS
Old 05-24-2006, 11:24 AM   #2
520
STi > EVO... Wait what???
Car: 03 EVO
Fav Mod: stock :(
IWSTI Addict since: Oct 2005
Send a message via AIM to 520
What did you make power wise before the heads?
Also what octane?
Nice job.
Old 05-24-2006, 11:26 AM   #3
Car: Your STi ;)
Fav Mod: Everything
^^^ Never tested before the heads with this turbo, but similar cars make 480ish...
Good point about the octane, straight 93, plus the water/meth.
SS
Old 05-24-2006, 08:23 PM   #4
520
Car: 03 EVO
Fav Mod: stock :(
nice work.
Old 05-24-2006, 08:39 PM   #5
Car: 05 Subaru WRX STi
Fav Mod: FP Red and Meth
Send a message via AIM to luSTI
Well I made 485whp, but I am running 28psi tapering to 25psi, so essentially I am running 25psi as far as hp numbers are concerned. I havnt seen any other FP Reds on meth with an EWG that have held 28psi+ to redline before this one. All the others have either tapered down like mine (because of the internal WG), the clutch has started slipping, or it has started misfiring horribly uptop so they couldnt get final numbers. Not to put down your results because 545whp is a VERY nice number. Just adding some imput since you said this car hadnt been dynoed before the heads.
luSTI is offline   Reply With Quote
Old 05-27-2006, 08:55 AM   #6
Car: 10 sec STi, 08 Z06
Fav Mod: TopSpeed
IWSTI Addict since: Aug 2004
congrats!
burnin4 is offline   Reply With Quote
Old 05-27-2006, 09:09 AM   #7
Car: 04' wrb Cosworth STI
Fav Mod: nukeworker
IWSTI Addict since: Apr 2005
The car with stock heads and the FP green on 93 octane and 50/50% water meth mix was tuned on Topspeed's dyno. Doug got that 3" green to put out 452whp and 460trq. The only thing that changed was the turbo,heads and cams.
modifyd is offline   Reply With Quote
Old 05-27-2006, 09:09 AM   #8
520
Car: 03 EVO
Fav Mod: stock :(
what tweaks were done to the meth inj. kit?
Old 05-27-2006, 09:13 AM   #9
Fav Mod: nukeworker
No tweaks just a snowperformance kit spraying a 50/50 mix.
