Old 05-03-2006, 04:38 PM   #1
Car: 96 Time Attack RS
Fav Mod: 06 STi swap
IWSTI Addict since: Apr 2005
Send a message via AIM to TopSpeed
Default Dyno Tested: Deadbolts SZ60= 498hp
2004 STI
Mods: TGV delete, helix 860cc injectors, Walboro fuel pump, Perrin FMIC, 3" turbo back exhaust with no cats, SMC meth inj, Tial BOV, DB SZ60, 6gun oil cooler kit, one step colder plugs, Perrin Big Maf, Topspeed Ecutek.
Run was made at 28psi holding to redline, on pumpgas with meth injection, at the end of the run we were seeing maf voltages of 4.82v.
SAE GRAPH
UNCORRECTED GRAPH
No here is where it gets interesting, this comparison is of the SZ60 vs a rotated GT30r kit. Both cars have identical mods, and both cars were run on pumpgas with meth injection at 28psi. You can see from the graph the stock placement SZ60 spools almost (and I mean almost) as fast but makes a ton more power up top.
GT30r vs SZ60
OK so whats next.... humm lets see how it stacks agains a rotated GT35r. Again both cars have the same mods, and both were run at 28psi on pumpgas and meth. Here you can see that the SZ60 spools faster but doesn't make as much up top as the 35r, which can be expected from the smaller hotside (SZ60). Even though the spool up on the graphs don't look much different, I can tell you that the SZ60 spooled much quicker on the street than the 35r, and on boost response was also much quicker.
GT35r vs SZ60
Enjoy,
Doug
TopSpeed is offline   Reply With Quote
Old 05-03-2006, 05:28 PM   #2
Car: 05 Subaru WRX STi
Fav Mod: FP Red and Meth
IWSTI Addict since: Mar 2005
Send a message via AIM to luSTI
Hmmmm interesting results. I would be interested to see how it compared to the Red as well. Looks like it spools slower than the Red. Makes good power and has good spool though for that big of a turbo.
luSTI is offline   Reply With Quote
Old 05-03-2006, 06:54 PM   #3
Car: '04.5 STi
IWSTI Addict since: Apr 2006
How much do you estimate this turbo will make without meth? Would a lack of methanol change the curve much?
Old 05-03-2006, 08:09 PM   #4
Car: 06 Subaru WRX STi: A
Fav Mod: exhaust
IWSTI Addict since: Oct 2005
going to jack this thread for a second.
What's the difference between sae corrected and not corrected dyno plots?
battlecat is offline   Reply With Quote
Old 05-03-2006, 09:13 PM   #5
Fav Mod: EQ Tuning
IWSTI Addict since: Apr 2004
dang i knew i should gone bigger!
BM_STi is offline   Reply With Quote
Old 05-03-2006, 09:36 PM   #6
Car: 10 sec STi, 08 Z06
Fav Mod: TopSpeed
IWSTI Addict since: Aug 2004
famous quote for all STi owners
burnin4 is offline   Reply With Quote
Old 05-03-2006, 09:59 PM   #7
Car: 05' CGM on silver
Fav Mod: Ed's tune!
IWSTI Addict since: Sep 2004
Send a message via AIM to USAF_STi
Should have went with a Red.
USAF_STi is offline   Reply With Quote
Old 05-03-2006, 10:40 PM   #8
Fav Mod: EQ Tuning
Naw, I dont like having a 5k and up usable rev range.
Old 05-03-2006, 11:28 PM   #9
IWSTI Addict since: Jan 2003
Send a message via AIM to CreoWRX
Just remember that the GRuppe-S dyno reads low.
-Mike-
CreoWRX is offline   Reply With Quote
Old 05-04-2006, 06:57 AM   #10
I Has a Turbo Timer
Fav Mod: Every single one!
IWSTI Addict since: Jun 2005
Trader Rating: (29)
Wow, very impressive!!! Damn, imagine if that was on a built block! WOW!
Old 05-04-2006, 07:00 AM   #11
Poor Speed Racer
Car: 96 328
mother of god!!!
Old 05-04-2006, 09:25 AM   #12
Car: 06 Black STI
Fav Mod: Turbo
Why does the 30R dyno pull start @ 3500 RPM's and the SZ60 starts @ 2900 ???
You can't compare the turbo's like that the SZ60 had more time to start spooling. Just imagine if they started @ the same time.
I've rode in a car with a 30R and it out spools my SZ55 same turner, same dyno.
gilmore25 is offline   Reply With Quote
Old 05-04-2006, 01:57 PM   #13
Fav Mod: Ed's tune!
A red hits peek torque just a few hundred rpms slower than a FP green. I should be hitting full boost a tad below 4k.
Old 05-04-2006, 06:49 PM   #14
Fav Mod: EQ Tuning
Im not so sure, theres guy that goes to the meets now he has a 06 sti. he has a red and supporting mods, and he says it kicks at 5k and up.
Old 05-04-2006, 07:29 PM   #15
Fav Mod: Ed's tune!
Really? is he running on just pump gas?
