Old 02-10-2006, 04:41 PM   #1
Car: STI's ;)
Fav Mod: Coolest Vendor Ever
IWSTI Addict since: Aug 2003
Send a message via AIM to RallySportDirect Send a message via Yahoo to RallySportDirect
Default BDL Industries Fuel Rail Kits and Throttle Body Spacers now available
Rallysport Direct now offers BDL fuel rail kits and throttle body spacers for your WRX.
The kit not only includes two Fuel Rails tapped with -8 ports and our unique -6 port on the belly of the fuel rail, a central fuel block, which incorporates the factory FPR, tapped with -8 inlet ports, a -6 return, ¼” port for a Fuel Pressure Gauge each piece anodized in BDL’ exclusive Bronze or the infamous WRX Blue but also an optional plethora of Steel Braided Teflon Line to ensure safe fuel flow at maximum capacity. Whether you’re opting for a complete fuel system change over or an upgrade this kit has it all. Available as a complete kit or Fuel Rails only.
The Vacuum Spacer is a first of its kind design. Created from CNC Billet Aluminum, designed to Increase Torque, Air Flow by increasing the Plenum Length.
Alleviate Vacuum T-offs and never lose vacuum pressure again to remote locations. The spacer incorporates (5) vacuum ports; 3 10/32” ports and 2 1/8” ports allowing hose ranging from 4mm up to 8mm which can be used for anything requiring vacuum from a Fuel Pressure Regulator, Blow Off Valve, Waste Gate, Map Sensor to IAC Valves. It can also be used in conjunction with any Nitrous Kit. Anodized Clear for Durability and Longevity.
The throttle body spacers are $124.00
The fuel rail kits are $495.00
BDL Industries products remain unparalleled in performance and are unsurpassable in quality, value and design. They are constantly staying on the edge of research and development to bring you the latest in high performance accessories for your automobile whether you’re tearing down the track in 6 seconds or taking your daily driver to work BDL Industries is there. All products are manufactured in house in the USA.
Jason
Rallysport Direct
www.rallysportdirect.com
RallySportDirect is offline   Reply With Quote
