Old 02-10-2006, 12:25 PM   #1
Car: STI's ;)
Fav Mod: Coolest Vendor Ever
IWSTI Addict since: Aug 2003
Send a message via AIM to RallySportDirect Send a message via Yahoo to RallySportDirect
Default Rallysport Direct now has the new Greddy Intelligent Informeter
Greddy has finaly released their new Intelligent Infometer and it has been added to our website.
The Greddy Intelligent Informeter is a inexpensive solution to monitor your your veichles parameters via the factory OBDII Port. This will allow you to read up to 25 pieces of information.
Communicates with the factory ECU to read up to 25 Channels Like: Speedometer, RPM, Water Temp, Ignition Timing, Injector Rate, Intake Air Temp, Fuel Temp, Air Flow Voltage, Intake Manifold Press, 02 Sensor Voltage, A/F, Battery Voltage, Throttle Position, WGV, ATF Temp, EGR Temp, Gear Position, 4WD Ratio, Exhaust Temp.
Along with being useful it is also stylish. The face plate can be changed to different colors to match your interior as well as the display background.
For use with veichles wich use OBD2 Ports, a cigarette lighter plug powers up the unit.
Features a easy to read Color LCD Screen, Monitor Record and Playback, and 180 Degree Monitor Flexibility.
This unit will work with all OBDII Veichles, although, only some Parameters will be able to be displayed.
Jason
Rallysport Direct
www.rallysportdirect.com
RallySportDirect is online now   Reply With Quote
Old 02-10-2006, 01:19 PM   #2
Fav Mod: JDM Pink Struts
IWSTI Addict since: Jul 2005
Send a message via AIM to Allen504tke
and the big ? is how much
Allen504tke is offline   Reply With Quote
Old 02-10-2006, 01:58 PM   #3
Fav Mod: EQ Tuning
IWSTI Addict since: Apr 2004
+1 on the price
BM_STi is offline   Reply With Quote
Old 02-10-2006, 02:01 PM   #4
Car: 05 WRB/Gold
Fav Mod: Hood Scoop Homer
IWSTI Addict since: Jul 2004
yea, for $150 i'd def think about it
Old 02-10-2006, 03:00 PM   #5
IWSTI Addict since: May 2004
holy christ its a Greddy IPOD...+1 more for price
chowder31 is offline   Reply With Quote
Old 02-10-2006, 03:18 PM   #6
Car: 05 CGM STi
Fav Mod: Topspeed tune
IWSTI Addict since: Oct 2005
Would this be a viable alternative to an EGT gauge?
revnup is offline   Reply With Quote
Old 02-10-2006, 04:24 PM   #7
Fav Mod: Voltex!
IWSTI Addict since: Mar 2005
greddys good, blitz is better.
sorry im a blitz fan
STIBLITZ is offline   Reply With Quote
Old 02-10-2006, 04:32 PM   #8
Car: EZ-GO
IWSTI Addict since: Feb 2004
$360
http://www.rallysportdirect.com/shop...oducts_id/2278
Cheers!
Hawaii_guy
Hawaii_guy is offline   Reply With Quote
Old 03-23-2006, 03:04 AM   #9
Car: ww 08 evo mr
IWSTI Addict since: Feb 2005
Can you read boost on this thing? how bout A/F ratio?
Bolshoi125 is offline   Reply With Quote
Old 03-23-2006, 05:16 PM   #10
Car: STI's ;)
it can only "read" what the ecu sees. if you use an fcd than you will see the boost that your ecu is seeing. as for air fuel ratio the factory ecu only sees a narrow band. this is in no way to be used as a wideband o2 sensor.
-Jason
Old 08-13-2006, 03:25 PM   #11
Car: 2006 Subaru Impreza
Fav Mod: Stage 2 - Protuned
IWSTI Addict since: Jun 2006
Default Freezes up when pushing intercooler sprayer
Does anyone else have this? I have this and the greddy informeter freezes up when I push my intercooler sprayer..... In order for the greddy informeter to unfreeze I have to unplug the sensor under the steering column. Otherwise it works great? I have an 06 sti. I am wondering if this is a common problem with these? thanks
DOMIN8 is offline   Reply With Quote
Old 08-14-2006, 11:12 AM   #12
Car: STI's ;)
DomIN8 - I have not heard of anyone having this problem. I know you have probably heard this befrore, but did you double check to make sure everything was installed correctly?
Let me know
Thanks
Rick
Old 08-14-2006, 11:12 PM   #13
Yes it is installed correctly..... Must not work for STI 06.... It works fine as long as you dont activate the intercooler sprayer.
Too bad.....
Old 08-15-2006, 02:33 AM   #14
Banned
Car: R.I.P WRB 06 STi
Fav Mod: ~ HKS Ti ~
IWSTI Addict since: May 2006
Send a message via AIM to HKS whore
lol ! .. it does look liek a ipod
HKS whore is offline   Reply With Quote
Old 08-16-2006, 10:05 AM   #15
I called technical support at Greddy... They are having no known problems with the STI 's up till 2005... But They ARE having compatibility issues with the 2006 STI's.... They are going to call me in one week to see what greddy plans to do with this.... Ill keep everyone posted....
