Old 02-08-2006, 09:37 PM   #1
Car: Family, Car.
Fav Mod: Anything MadDad
IWSTI Addict since: Mar 2005
Default MadDad(TM) Clarity V2's First Photos
While the current line of Clarity gauges will soon be gone(the last incoming orders of the current line are this month) we thought the timing was right to show what we are doing with the updates. The updates are subtle but important. Since their introduction Clarity gauges have been immensly well received. Our goal was to introduce a no frills set of reliable, affordable performance gauges that looked as great as they function and by all accounts we accieved that goal in spades based on customer reactions and emails we received literally thanking us for introducing them. However we also take to heart comments customers have to help us improve our products and even though our gauges have only been on the market since October we are already at the point where we are releasing the second coming. So what is changing:
* Mechancial boost gauge being replaced with an electronic unit
* Boost gauge will use 4 tick marks between each major tick so that every tick represents 1 PSI. Currently version every tick is 1.25 PSI. No real biggo but we figure on the boost have the extra tick will be welcome. The remainder of the line will keep the 3 tick marks since this is what the factory cluster has and we see no advantage for adding more ticks to the other gauge faces.
* Extended range on Oil Press to go beyond the normal 100 PSI that is typical.(most cars are pegged at 100PSI on startup).
* Revised sending units where applicable to support new scaling.
* Additional read point on the Water Temp and Oil Temp to make it easier to see what your temp at a quick glance.
* Font changed on all gauges to be a near identical match to the factory cluster. While no one has complained about the face on the current line, the reality is it's really no where near a match for the factory cluster font, nor are the vast majority of gauges currently on the market, so we flipped through about 400 font styles and choose one that near perfection. The V2 Clarity's will positively be the best matched gauges for a Subaru vehicle. Others might claim a WRX look but MadDad(TM) Clarity V2's will have the face to back up the claim.
* The MadDad(TM) Clarity branding will be visable, however, it will tucked in the lower right corner keep the center of the gauge face logo free, reinforcing the clean look that everyone has loved thus far.
* Will be available in STi Amber/Red, Green, and White.
For those not familiar with MadDad(TM) Clarity Gauges, they do a STi/Defi style black-out effect when off.
The following image is the final graphical mock up but it shows the font and gives a good general idea of what is coming. The V2 Clarity gauges will no longer be at the "intro" price that we somehow have been running since October . Still, you won't find a better value anywhere for a full set of electronic gauges with precision sending units. Boost, EGT, and your choice of Oil Press, Oil Temp. or Water Temp will still be just $395 even without the intro pricing and with all the updates. You won't find a better match to your Impreza anywhere.
Here is a boost sampel in Amber/Red to give you a better idea.
daddysscp is offline   Reply With Quote
Old 02-09-2006, 02:29 AM   #2
GZA
Super Moderator
Car: 2005 STi
Send a message via AIM to GZA
Looks great, so when are these supposed to come out?
GZA is offline   Reply With Quote
Old 02-09-2006, 05:42 AM   #3
How YOU Doin?
Car: 2006 Audi S4
Fav Mod: OMGHI2U!
IWSTI Addict since: Apr 2004
Send a message via AIM to jsh139
Yes! I can't wait for these to come out. I know it's petty, but the mechanical boost and 1.25 psi tick marks really bothered me. It's worth the extra 100 bones to get something that you like.
I am assuming that these are like the V1 gauges? i.e., no peak memory/warning lights? Also, will you be doing a similar deal if we order these with an ATI pod and sandwich adapter? *praying*
Thanks,
-Josh
jsh139 is offline   Reply With Quote
Old 02-09-2006, 03:36 PM   #4
Car: Family, Car.
We're going to get the full 5 gauge set one-offs expidited early next week for our final approval. If all is good as I expect it to be we should see a production run at our door sometime in late March.
Still no frills other than the STi black-out effect. You'll be able to purchase the electronic trio of boost, egt and oil press(or oil temp/water temp) for $399 which will still make these one of the absolute best values, and unmatched in their OEM look.
- Rich
Old 02-10-2006, 08:46 PM   #5
Car: Family, Car.
Just thought I'd point out something. The graphic mock up we have shown is just that. It is there to show the general layout and font so that you can see how these will be the best factory matched gauges available. But they are mock ups and a couple of things will be addressed in the final gauges that are not represented correctly in the mock up. The main point being, the Water Temp, Oil Temp and EGT will all use the same 20 degree jump between each display point. Right now there is a 20, 25 jump alternation. That won't be the cause on in the real mckoy. The production will all use the same consistant scale of 20 degrees between each jump.
- Rich
Old 02-10-2006, 09:34 PM   #6
Indiatr0n in yo IWDPL
Fav Mod: Brum Brum
IWSTI Addict since: Jun 2004
2007 Postwhore King
I'm interested. Will the gauges be sold individually, and if so, how much will the oil pressure and oil temperature gauges be?
Also curious about the sandwich adapter...
Old 02-10-2006, 09:36 PM   #7
STI Master
Car: E46 M3
Fav Mod: ZCP Wheels
IWSTI Addict since: Aug 2005
Trader Rating: (77)
Nice!
props for coming out with something for people with a tight budget...
Im sure these will get popular!
Old 02-10-2006, 09:58 PM   #8
Car: 05 STi PSM
Fav Mod: Scooby Sport DP
IWSTI Addict since: Sep 2005
Beautiful
silver arrow is offline   Reply With Quote
Old 02-11-2006, 05:31 PM   #9
Car: Family, Car.
Regular single gauge prices will be as follow:
EGT $179.95
Boost $129.95
Oil Press. $129.95
Oil Temp $129.95
Water Temp $129.95
Any combo order(for gauges, not gauges + optional pods/accessories) for $308 or more will get 10% off before you are charged.
- Rich
Old 02-14-2006, 08:01 PM   #10
Car: Family, Car.
Just a heads up. There is a revised mock in the first post. The scaling on the Water Temp, Oil Temp, and EGT were slightly off in the origonal sample. These gauges are due around end of March. Part #'s are up on the website now. Listed as MadDad(TM) Clarity Version 2 Black-Out LED gauges. The only ones posted right now are the Amber/Red. No charge until we ship. Ordering early just means we ship to you first when the do arrive. We do not charge for products until we ship them so order as early as you like without fear of being charged now.
I redid the boost mock up in Amber/Red to give a better feel for how the V2's will look for your STi's.
Old 02-14-2006, 08:21 PM   #11
please tell me that there is a peak warning light. these gauges will go extremely fast in my area if they will .
rob142sti is offline   Reply With Quote
Old 02-14-2006, 08:31 PM   #12
GZA
Super Moderator
Car: 2005 STi
Will you guys have some kind of single steering column pod for these?
Old 02-28-2006, 06:51 AM   #13
Car: 05 MCS
IWSTI Addict since: Aug 2004
What is the gray "dot" in the lower right between the branding names?
/zp
zp2063 is offline   Reply With Quote
Old 03-03-2006, 09:14 AM   #14
Car: 05 MCS
As answered in another thread by Daddy:
"It won't be visable on the gauge. It's a face mounting point. No warn light, at least not on the entry level V2's that are replacing the current line soon. "
Old 03-03-2006, 10:05 AM   #15
Car: 200? WRX STI
Fav Mod: Super EX/RM-01A
IWSTI Addict since: Nov 2005
Send a message via AIM to o2sys
make it sweep and it will be set~
o2sys is offline   Reply With Quote
