| | #46 |
| Meth Junkie Car: Steel Gray 06 STI Location: Edison, NJ Posts: 935
IWSTI Addict since: May 2004 Trader Rating: (4) | ^^^ yes you do This ad is not endorsed by this member. Please register or login to hide this ad. |
| | #47 | |
| Professional STI Racer | Quote:
No but they say stock should be around 210ish ... the reason my numbers are so low is I may have a leak in my inlet pipe so MZM said I could make up some lost power after doing the inlet... | |
| | #48 | |
| Professional STI Driver Car: 04 ALPINE WHITE STI Fav Mod: Not sure yet Location: Clarksville, TN Posts: 460
IWSTI Addict since: Jan 2006 Trader Rating: (3) | Quote:
| | #49 | |
I would love to know this also. PETER CAN YOU PLEASE CONFIRM? Thank You! | |
| | #50 | |
| | #51 |
| Moderator & ECU Tech
Car: 05 CGM STI Fav Mod: mo boostaz Location: Fredneck, MD Posts: 3,716
IWSTI Addict since: Jun 2004 Trader Rating: (6) | Regarding TGV deletes: AFAIK, the interference is between the turbo and the sensor/motor on the TGVs. That has nothing to do with the inlet. t |
| | #52 | |
| The Next Petter Solberg Car: 08 Z06 Corvette Fav Mod: Jack Jack Location: Portland, OR Posts: 882
IWSTI Addict since: Oct 2005 Trader Rating: (3) | Quote:
The turbo itself bangs on the sensor. It could actually work fine until that banging had some effect... however once you have seen the throat that the port is forced down to in the TGV, you want it out of your car. | |
| | #53 | |
| Junior STI Driver Car: 04 STi PSM Fav Mod: my butt dyno Location: Pittsburgh Posts: 113
IWSTI Addict since: Jun 2004 Trader Rating: (0) | Quote:
Justin | |
| | #54 |
| Sold My Soul For Mods Car: '05 CGM STi Fav Mod: Track Time Location: Bethesda, MD Posts: 6,668
IWSTI Addict since: Jun 2004 Trader Rating: (14) | it seems pretty unlikely that you would be able to work a solid pipe in there without removing the manifold. Although both ends are silicon so it might be possible. |
| | #55 |
| Professional STI Driver | Alright then so this still requires TGV deletes ? Would not make sense if it didn't since APS also sells the deletes .. Still a very nice piece and I'll probably get it or whoever makes a solid piece first. |
| | #56 |
| Muller Chevrolet
Car: 08 Chevy 2500 Diesel Fav Mod: a new 09 STi Location: Milford, NJ Posts: 10,152
IWSTI Addict since: Oct 2004 Trader Rating: (11) | still confused on the TGV issue. Last edited by VSGTS14; 02-02-2006 at 03:00 PM. |
| | #57 |
| Muller Chevrolet
IWSTI Addict since: Oct 2004 Trader Rating: (11) | do you think it will fit with a perrin big maf intake also with perrin fmic? |
| | #58 | |
| Grassroots STI Racer Car: 01 Subaru WRX STi Sp Fav Mod: Coming Soon Location: Australia Posts: 519
IWSTI Addict since: Oct 2005 Trader Rating: (0) | Quote:
The best feature/benefit (the entire reason for the APS turbo inlet pipe development is to provide high mass air flow for the larger turbochargers or stock turbos running higer boost pressure) imho is the huge power gains when used in combination with SR 55 sized turbos as the APS turbo inlet pipe reduces the huge restriction caused by the tiny stock plastic STI turbo inlet duct, all good. Peter | |
| | #59 | |
Peter | |
| | #60 | |
IWSTI Addict since: Jun 2004 Trader Rating: (6) | Quote:
You didn't say specifically weather TGV deletes are still required for 3" inlet turbos when using your intake pipe. I thought the interference came between the turbo and the TGV sensor/housing. Thus, an inlet pipe has nothing to do with this and TGV deletes will still be necessary. Please comment to clear up this issue. State what the interference is and how your inlet pipe changes things. t This ad is not endorsed by this member. Please register or login to hide this ad. | |
