| | #136 | |
| Platinum Member Car: 2005 & 2008 STI Fav Mod: UR 35R and Hydra tune by Scott Siegel :) Location: Columbus, GA Posts: 1,930
IWSTI Addict since: Mar 2005 Trader Rating: (11) | Quote:
| | #137 |
| Junior STI Driver Car: 02 wrx wagon, multip Fav Mod: 257 swap Posts: 53
IWSTI Addict since: Jun 2005 Trader Rating: (0) | If it hasn't collapsed yet, do you notice any difference in power or is it too small of an upgrade to tell either way. Also, how does it sound? A couple people on the NASIOC Forum stated it made the turbo louder!?!?! |
| | #138 | |
![]() It is made of metal not silicone. Yes, the turbo is very loud. With my FP Red anyway. But I like it that way. I put the inlet on with the new turbo, but I'm sure there is a gain over the stocker. | |
| | #139 |
| Spec C Club Car: '04 WRB Fav Mod: A working ECU... Location: CT Posts: 1,486
IWSTI Addict since: May 2003 Trader Rating: (7) | Well JDM, how was the install? Did you also do the TGV delete? For all the work of getting this APS inlet installed, I think we'd be crazy not to do the delete while the manifold is off. It seems fairly simple, remove the butterfly, motor, etc. and weld that hole shut. I'm 90% set now on the APS inlet, 3" 20g, NISMO injectors, 1 step colder NGK... |
| | #140 |
| Muller Chevrolet
Car: 08 Chevy 2500 Diesel Fav Mod: a new 09 STi Location: Milford, NJ Posts: 10,144
IWSTI Addict since: Oct 2004 Trader Rating: (11) | i believe JDM did not do the TGV delete, instead he shaved something...he'll be able to explain. |
| | #141 | |
IWSTI Addict since: Jun 2005 Trader Rating: (0) | Quote:
. Anyway, did you have to pull the manifold for the install? Peter was saying it was a certainty but I was hoping someone found a "quick and dirty" way to do it without the time-consuming job of manifold removal. Thanks, Supremo Last edited by Supremo; 03-04-2006 at 12:51 AM. | |
| | #143 | |
IWSTI Addict since: May 2003 Trader Rating: (7) | Quote:
| | #144 |
| Junior STI Driver Car: 1996 SUBARU Legacy Fav Mod: Hankook C50 Location: St. Augustine, FL Posts: 95
IWSTI Addict since: Sep 2005 Trader Rating: (1) | There's been several times that I've done it with customers standing around...they look away...then back..."WHOA!!! Where'd my intake manifold go?????" |
| | #146 |
| Lurker | Just wanted to post a couple points here. I tried installing one of the APS inlet's on my 04 WRX. 04 WRX's and later I would assume have the same flow sensor or whatever that requires you to cut piece 8 and use piece 9. I believe those are the right numbers. And for the part that really bummed me out. The inlet will not fit under a reversed intake manifold. The way the manifold is designed one runner sits higher than the other. When the manifold has the TB facing backwards the higher runner is at the front of the car. When the TB is facing forwards now the lower runner is at the front of the car. I may be making spacers.. about 1/2" to raise my manifold so the inlet will fit. |
| | #147 | |
| Professional STI Driver Car: 04 ALPINE WHITE STI Fav Mod: Not sure yet Location: Clarksville, TN Posts: 460
IWSTI Addict since: Jan 2006 Trader Rating: (3) | Quote:
| | #148 | |
IWSTI Addict since: Sep 2005 Trader Rating: (1) | Quote:
| | #150 | |
| Amateur STI Driver | Quote:
