Closed Thread
Old 11-28-2005, 04:07 PM   #1
Authorized Manufacturer
Fav Mod: COBB Tuning
IWSTI Addict since: May 2005
Default COBB Billet Double Adjustable Shifter
As of 11/23/05 COBB Tuning is pleased to announce the release of our STi 6 speed adjustable short throw shifter.
Designed using CAD technology, the COBB Blue anodized billet shifter body is CNC machined from 6061 Aluminum. Like our original design, the shift throw distance and shift knob height are independently adjustable and both can easily be adjusted with the shifter installed in the vehicle. Stainless Steel socket head screws are set in a counter bore for a flush mount and provide a clamping force that firmly holds the upper and lower slider shafts in place. This new design improves the ease of making adjustments while also being significantly stronger. Leaves reverse lockout fully functional at any desired knob height or throw distance. OEM style delrin sleeve on upper shaft for smoother reverse lockout engagement and vibration dampening.
Compatible with the factory shift knob or any aftermarket knobs designed to replace the factory unit
More information via the URL listed below:
http://cobbtuning.com/sti/drivetrain-i.html#shifter
Justin
COBB Tuning
COBB is offline
Closed Thread
