Old 11-07-2005, 09:34 AM   #1
Car: 06 B-SPEC Legacy wit
Fav Mod: AP Pedals and Motons
IWSTI Addict since: Oct 2005
Send a message via AIM to GTWORX.com
Exclamation Swift Springs!!!!
GTWORX is proud to announce that they are now a Swift Dealer.
SWIFT SPRINGS
These springs are designed uniquely for each application. The goal for these springs is to maximize the handling performance. While some springs are designed to lower the car, Swift's are designed to maximize the performance without sacrificing the comfort.
252/224 Spring Rate for STI
04 STI has a 25mm front and 20mm read drop
05 + has a 30mm all around drop
H5S.TW: Motorsport’s Most Advanced Spring Material
Swift made a name for itself on the tracks of Asia and Europe by defying all accepted concepts and speculations about the future, if any, in coil spring science. When everyone else was looking to expensive and brittle titanium composites to create the next evolution of springs, Swift was looking at reinventing the entire science of coil spring dynamics. Swift saw that most others are using the old silicone chrome material which was soft and heavy. It used a tempering method that damaged the strength of the material requiring more coils and, in turn, more weight. The material was also suffering from a short life-span. With springs like this leading the industry, Swift saw room for improvement.
Swift’s R&D team created material, called H5S.TW, which was stronger than silicon chrome. It was so resilient that it required 2 rounds of shot peening in order to hold its coil shape and was so strong that it needed thinner wire compared to other manufactures. It also needed fewer coils, which greatly decreased weight while dramatically increasing available stroke.
The biggest difference was the consistency of the spring rate (see graph below for comparison of spring rates between Swift and the top 2 motorsport linear spring lines). Every manufacture uses different methods to rate their springs, causing frustration among many racers when they swap brands. Brand A may test the 1st inch of stroke while brand B may test the 3rd inch of stroke. By looking at the diagram below, you will get a clearer picture of how this works.
GTWORX.com is offline   Reply With Quote
Old 11-07-2005, 01:56 PM   #2
jph
Car: the wagon
IWSTI Addict since: Apr 2004
Originally Posted by GTWORX.com
[color=Magenta][b]252/224 Spring Rate for STI
those rates are a pretty close match for the jdm pinks.
how do they compare ?
J.
jph is online now   Reply With Quote
Old 11-08-2005, 04:14 PM   #3
Car: 05 WRB/Gold
Fav Mod: Hood Scoop Homer
IWSTI Addict since: Jul 2004
also interested
Old 02-03-2006, 10:30 AM   #4
Car: 06 Aspen White STi /
IWSTI Addict since: Jan 2006
Send a message via AIM to scottjua Send a message via Yahoo to scottjua
+ 1 for above two guys
scottjua is offline   Reply With Quote
Old 02-07-2006, 02:52 PM   #5
They are almost exact to the pinks is every way..except price
