Old 10-06-2008, 03:23 PM   #1
Car: STI's ;)
Fav Mod: Coolest Vendor Ever
IWSTI Addict since: Aug 2003
Send a message via AIM to RallySportDirect Send a message via Yahoo to RallySportDirect
Default Elite AWD 3" Down Pipe to Stock Cat Back/ Tapered Cat Back Adapter
This adapter is the answer for the guys and gals out there running an after market 3” down-pipe working in conjunction with the factory cat-back and/or Cobb cat back. This adapter slides into most aftermarket 3” down-pipes and creates a smooth tapered transition down to the factory sized tubing and allows for the use of the factory donut gasket. By utilizing the factory donut gasket flexibility will be restored to your exhaust system along with a factory like seal “Say good bye to exhaust leaks!!!” And last but not least when you are ready to upgrade to a 3” cat-back just remove our adapter and take advantage of a true full 3” turbo back system!!
100% 304 Stainless Steel Construction
Kit Includes: (1) EliteAWD.com Stainless Donut Gasket adapter (2) Shoulder bolts (2) Washers (2) Nuts (1) 2 bolt 3" std flat gasket
Note: Factory donut gasket not supplied in kit. Donut gasket off of your factory down-pipe will work perfectly.
WILL NOT WORK WITH HKS DOWN PIPES! Or pipes smaller then 73MM Inner Diameter.
Now In stock!
MSRP 45.99
LINK TO ITEM
LINK
RallySportDirect is offline   Reply With Quote
Old 10-06-2008, 04:25 PM   #2
Car: '06 OBP STi
Fav Mod: Driver's Ed
IWSTI Addict since: Sep 2006
Default Re: Elite AWD 3" Down Pipe to Stock Cat Back/ Tapered Cat Back Adapter
FINALLY! A cheap way to go Stage 2 and keep my Genome! I'm ordering one right now!
cekeel is offline   Reply With Quote
