Go Back   IWSTI.com: Subaru STI Forums > STi Marketplace > Vendor Announcements & Project Buildups
Old 07-15-2008, 11:30 AM   #1
Car: 04/08STI 95SVX 86E30
Trader Rating: (53)
Default New Kartboy 08 rear subframe bushings are here!!
Kartboy Rear Subframe Bushings
2008 Rear subframe bushings Turn In Concepts
Install and impressions
The rear subframe bushings are the latest and greatest product from Kartboy specifically designed for the 08 Impreza chasis. These bushings are added to the lower portion of the four rear subframe mounts and are designed to help hold the subframe in place during acceleration or turning. The bushings are sandwiched between the lower metal flange/washer holding the subframe and bushings that isolate the subframe from the frame.
Install
The install is quite easy and should take no longer than 30 minutes to perform. It involves removing the large bolts and metal flange/washers one at a time from the subframe followed by inserting the new bushings and tightening down the large bolts. There are four bushings in total that need to be installed with the kit.
This first picture shows the location of the left rearward mount. You can see the large (19mm) bolt head that I am pointing to and the metal flange/washer above the bolt head. This large bolt needs to be removed. It is only torque to about 60 ftlbs and should be removed easily.
This is the large bolt and flange/washer removed from the car.
This shows the approximate location of the bushing on the large flange/washer.
You can see that the flange/washer and bolt have been removed in this picture. The bushing will go into the void area seen between the metal sleeve and outside ring of the stock bushing.
Here you can see the proper installation of the bushing in relation to the stock bushing and large flange/washer.
[img] http://www.turninconcepts.com/forums...N3604_copy.jpg [/img]
After installing the bushing, make sure you tighten the bolts back to around 60 ftlbs. That’s it for the first mount. The other three follow similarly. The fronts have a larger flange/washer that is also a chasis bracket. The front mounts have two 14mm headed bolts holding the front of the bracket along with the 19mm headed long bolt in the rear of the bracket.
This is the front portion of the mounts in the front.
And a picture of the mount removed from the car.
Impressions
I definitely notice a more connected feel with the rear of the car. Throttle response also seems a bit quicker . No increase in NVH that I have noticed yet, but I only took it on a quick test drive. More to come as I get the car out on track and have more time to drive it.
Tony
