Go Back   IWSTI.com: Subaru STI Forums > STi Marketplace > Vendor Announcements & Project Buildups
Old 06-25-2008, 07:30 AM   #1
Car: Where Real Power is
Fav Mod: Tuning & Performance
Default AMR T50R Bolt-On Turbocharger!!!!! Sexy :)
Here it is guys. Right off of the shelf! Our AMR T50R direct bolt-on turbocharger!
Notes:
One of the most fun drivable turbochargers on the market. Achieving full boost around 3000rpm-3600rpm (depending on modifications) causes the driver to get extremely throttle happy! Designed for those who want that QUICK SPOOL and TOP END POWER. The AMR T50R has a fully ported compressor housing and fully ported 7cm2 exhaust housing giving the turbocharger maximum flow. Along with the optional 3" compressor housing, this turbocharger is a fully done. Jammed with all of the goodies making it the best bang for the buck! Power levels range in the 330whp-400whp mark.
T50R Specs:
- 750-770 cfm
- 7cm2 exhaust housing
- 2.4" Compressor Inlet (optional 3" compressor inlet)
- Fully ported exhaust housing
- Fully ported compressor housing
- HIGH TEMP coated exhaust housing (increase spool time)
- OIL AND WATER COOLED!
- Includes ALL oil and water lines
- DIRECT BOLT-ON
Optional:
- Just when you think it couldn't get any better. We can include the optional 19-24psi Custom Built Actuator for an addition $190.00. This actuator is for those running heavy boost. This wastegate combined with the T50R makes boost taper a thing of the past. We have tested the T50R with this actuator holding boost straight to redline.
The CUSTOM actuator made for our T50R by FORGE is a thing of beauty.
Applications:
- ALL Subaru's
The T50R in the engine bay. Beautiful
The T50R sitting next the stock snail:
POWER:
Tuning Note:
- Vehicle: 2008 Subaru STi
- AFR: 10.5
- BOOST: 22psi
- TIMING: Conservative
Power: 350whp / 360wtq
-Rob
AutoMaster is offline   Reply With Quote
Old 06-25-2008, 07:55 AM   #2
Fav Mod: T2s and Recaros
Default Re: AMR T50R Bolt-On Turbocharger!!!!! Sexy :)
Whats the difference between this and a 20g? Will you offer an 8cm exhaust housing in the future?
Old 06-25-2008, 07:57 AM   #3
It is larger than a 20G. Yes we will be offering this in the future if the demand is needed. With the extreme ported and coated exhaust housing. The 7cm2 performs very well.
-Rob
Old 06-25-2008, 11:32 AM   #4
Fav Mod: Protune
-Rob
Any more specs on this? With 750cfm you are probably talking about something based off a GT3076 or Green size compressor? But it seems to spool quicker? What makes this different from the Blouch Dom 3 or ATP3076?
drofnums is offline   Reply With Quote
Old 06-25-2008, 11:40 AM   #5
Car: DGM 2008 STI
Fav Mod: Advan RZ DGM 18X9" +45
yeah does anyone know if this is bigger than the Blouch Dom 3 or is the Blouch Dom 3 bigger>?
Old 06-25-2008, 11:49 AM   #6
Car: 05 Crystal Grey
Fav Mod: AMR BIG MAF
I have been following the journal on the 2008 products. It is the same size as a DOM3 but you have a choice between 2.4" inlet or 3" and an optional custom wastegate upgrade. One guy on the thread called it a DOM3 on steriods hahahahahaha
Great job AMR! Keep it up!
SubySat is offline   Reply With Quote
Old 06-25-2008, 11:51 AM   #7
Car: 08 STI,sr20det 510
Fav Mod: boob job for wife
Blouch dom 3 is a 52lb wheel this is 50lb. If one was to go with the 3" inlet would I have to delete the tgv's?
Old 06-25-2008, 12:00 PM   #8
You are correct. This is a 50lb capable of 500hp. The 3" will make more power than shown above. The dyno sheet was based on the 2.4" inlet with those little mods. We have done everything you possible can to this bolt-on turbocharger.
The TGV's would have to be removed in order to run the 3" inlet. I am not a big fan of tight space.
Spool is really fast on this turbocharger. This is from all of the excessive porting and all the coating that was done. We wanted to design something that would have super fast spool and have some killer top end.
-Rob
Old 07-15-2008, 05:57 AM   #9
Here are some engine bay and product shots!
-Rob
Old 07-15-2008, 09:30 AM   #10
Good balance Rob, looks like it performs well
Old 07-15-2008, 09:33 AM   #11
Thank You!
-Rob
