Go Back   IWSTI.com: Subaru STI Forums > STi Marketplace > Vendor Announcements & Project Buildups
Old 06-22-2008, 11:14 AM   #1
Car: 03 Evolution 8
Trader Rating: (16)
Default Brembo Announces 2008 STi Brake Kits!
Brembo @ 201 Motorsports
201 Motorsports is an Authorized Brembo Dealer!
Brembo has introduced some new Gran Turismo Brake Kits for the 2008 STi! Check them out!
Brembo Gran Turismo 2-Piece 4-Piston Front Rotor Kit
355mmx32mm 2-Piece Rotor
Available in Black, Red, and Silver // Drilled or Slotted
$3495
Brembo Gran Turismo 2-Piece 6-Piston Front Rotor Kit
Available in Black, Red, Yellow, and Silver // Drilled or Slotted
$3695
Brembo Gran Turismo 2-Piece 4-Piston Rear Rotor Kit
345mmx28mm 2-Piece Rotor
$3295
201Motorsports is offline   Reply With Quote
Old 06-22-2008, 04:26 PM   #2
kaz
Car: 08 DGM STi
Default Re: Brembo Announces 2008 STi Brake Kits!
Have they tested bias between front/rear using the 6 piston? and using the rear kit do you lose E brake?
kaz is offline   Reply With Quote
Old 06-23-2008, 04:00 PM   #3
Car: 03 Evolution 8
Trader Rating: (16)
Brembo has tested the bias between the front and rear brake set-ups, but not as an official test. The Brembo engineers have about 10 different caliper bodies with 3 different piston combinations for each that they use in order to create their brake systems for the various applications. When I say that brake bias was tested, I mean that the engineers have put the brake set-ups that are effective and actually a performance upgrade for the specific vehicle into production because the balance of the new Brembo system falls in the bias range of the stock vehicle. This, in turn, results in a gain in performance and an upgraded braking system that will serve you well instead of hindering performance
With the rear brake kit for the 2008 STi, you actually retain the OEM e-brake
Old 07-03-2008, 10:25 AM   #4
Car: 08 STI
Fav Mod: Driver
What brake pads options are available for the 6-pot mono block front kit?
freeman is offline   Reply With Quote
Old 07-11-2008, 08:00 AM   #5
Car: 03 Evolution 8
Trader Rating: (16)
I'm sorry, I didn't see this post!!! As far as brake pads go, Brembo stocks Ferodo FM1000 and Ferodo DS3000 for use with this set-up. There are also offerings from PFC, Carbotech, and Porterfield
