Old 03-18-2008, 02:37 PM   #1
Car: 04/08STI 95SVX 86E30
IWSTI Addict since: Jul 2003
Trader Rating: (53)
Default REAR CAMBER PLATES by Vorshlag are HERE!!!
We've been waiting a very long time for these, and I'm happy happy happy to announce they are here. I mean seriously, really happy.
So here's the details:
  • Compatible with 60 mm Coil-Over springs (perches for 2.5" coming soon).
  • Installs with basic hand tools, no chassis modifications required.
  • Plates are designed specifically for 02-07 Impreza
  • Camber is adjustable at the track from the trunk with simple hand tools.
  • The spherical bearing used in Vorshlag camber plates is the largest used in any Subaru camber plate. The result has much better durability and wear characteristics than the undersized bearings used in some competitors' plates.
  • Designed using alloy steel, not aluminum, for the minimum stack-up height and maximum suspension bump travel. More than an inch more strut travel than some of our competitors!
  • 100% CNC machined, alloy steel construction - Tough as a German Tank!
  • All components plated for maximum corrosion resistance and long life.
And a couple of other things:
  • Camber challenged Wagon guys with sedan coilovers - this is something you really want to think about.
  • Vorshlag also added a nice little bonus - a single row bearing for the upper perch to allow it to turn freely while compressing and decompressing.
  • Stack height is ONLY about 31mm. This beats the heck out of the stack height that uses the stock top hats and upper perch adapter as that comes in at over 60mm.
These bad boys are $380 shipped, and here's the pics.
Big ol' pile of camber!!!
Old 03-18-2008, 02:46 PM   #2
Halliburton Mercenary
Car: AW GDF-D
Fav Mod: Q-Rack
IWSTI Addict since: Oct 2005
Trader Rating: (12)
Default Re: REAR CAMBER PLATES by Vorshlag are HERE!!!
Very cool!
How does one adjust these from the trunk?
Old 03-18-2008, 02:54 PM   #3
Car: '04.5 STi
IWSTI Addict since: Apr 2006
Originally Posted by fullerton View Post
Very cool!
By yanking out the back seat and contorting yourself in the oddest way possible.
lol @ "pay us you annoying bastard"
Old 03-18-2008, 03:08 PM   #4
Fav Mod: TiC AST's - 7/6K
IWSTI Addict since: Feb 2005
Looking good guys.
Old 03-18-2008, 03:08 PM   #5
Car: 04 Sti
IWSTI Addict since: Sep 2006
hahaha i hope that message is to an IWSTI member...
bigJP is offline   Reply With Quote
Old 03-18-2008, 03:17 PM   #6
Car: 05 WRB/Gold
Fav Mod: Hood Scoop Homer
IWSTI Addict since: Jul 2004
do you happen to know if they will fit on Ohlins Sportline's?
Old 03-18-2008, 04:38 PM   #7
Trader Rating: (53)
I happen to have a set of sportlines right here. In this config they will not, BUT I can talk to Vorshlag about getting the bits to make it work.
Here's what works -
The lower spool and bearing work fine.
The plate works fine.
To get them to fit right here's what we need -
Upper perch for a 65mm or 2.5"spring
Upper insert that has a larger center bore and is a shade taller on the flange.
Since Vorshlag as 21 different combos of spools and perches for the various BMWs this should be little problem.
Old 03-18-2008, 04:58 PM   #8
Trader Rating: (53)
Boondocksaint for that one.
Old 03-18-2008, 06:37 PM   #9
Trader Rating: (53)
Oh, and these will fit RCE T2s or KW V3's with 60mm springs....
Old 03-18-2008, 08:35 PM   #10
Car: 05 WRB/Gold
Here's what works -
alright cool, thanks or doing the hw on it. im not ready to buy now (saving for track day season, lol) buti definitely need them at somepoint in the near future. I'll talk to you guys when the time arises.
Old 03-19-2008, 09:11 AM   #11
Is Scared Of Kevin...
IWSTI Addict since: Nov 2006
im excited! mine are already on the way!!!!
MKTURBO is offline   Reply With Quote
Old 03-19-2008, 09:43 AM   #12
IWSTI Addict since: Mar 2006
TiC, don't forget to mention that angling your struts inwards (which camber plates do) increases your roll center height, decreases roll center migration, alters your roll axis angle, decreases roll couple, quickens your camber curve, and decreases body roll. The inclusion of a bearing for the spring perch in the rear will also help keep your rear spring more linear, too.
These changes are small but definately exist.
Additionally, the potential exists to run longer springs and thus have much more suspension travel, fit much wider wheels and tires, and of course, have more negative camber in the rear.
These aren't just for camber.
Old 03-19-2008, 09:45 AM   #13
approved this message.
Fav Mod: correct grammar
IWSTI Addict since: Jun 2006
Old 03-19-2008, 09:48 AM   #14
These, along with the coilovers and all my other goodies, go on Friday. I'm going to bring one of my summer wheels (17 x 8.5, +51, running 255/40s) and see what kind of clearance I get.
Old 03-20-2008, 12:15 PM   #15
Got my rear plates today. Beefy. The bearings are ginormous. They weigh a ton.
If you have the fronts, you know what I mean when I say these feel like they'll outlast the car. In the event of nuclear apocalypse, they can be removed and thrown to bring down prey (assuming you've got good aim). Barring that, they're going to give you control over rear camber for a long time.
How long? Well, they go on tomorrow. Mark your calendars and ask me when I'm fitty.
