| Authorized Vendor Car: STI's ;) Fav Mod: Coolest Vendor Ever Location: SLC, UT Posts: 1,723
IWSTI Addict since: Aug 2003 Trader Rating: (7) | The COBB Tuning Air Box was designed to capture the cool air supplied to the SF Intake through the factory intake snorkle. Constructed of 16 ga. Aluminum the air box consists of a one piece surround, directional lid, and stainless fasteners that help reduce a loss of power that could be robbed from your motor by a heated intake charge. Unlike some cold air intakes, which places the filter in the front fender, our design helps to supply cool air through factory ducting, while eliminating the risk of water ingestion. Comes with all necessary hardware and full illustrated instructions. Requires the use of the COBB SF Intake system. ![]() ![]() ![]() Thanks Kirill RallySportDirect.com 801-748-4910 ext 1006 This ad is not endorsed by this member. Please register or login to hide this ad. |
| | #2 |
| Muller Chevrolet
Car: 08 Chevy 2500 Diesel Fav Mod: a new 09 STi Location: Milford, NJ Posts: 10,162
IWSTI Addict since: Oct 2004 Trader Rating: (11) | so it's a complete box that surrounds the filter? that's very nice. |
| | #5 |
| S204 Racer Car: '04.5 STi Fav Mod: Whiteline steering rack bushings Location: Montgomery, Al Posts: 3,035
IWSTI Addict since: Apr 2006 Trader Rating: (0) | Is it recommended that you have the silencer tube in place in the fender area for this thing to give maximum benefit? ...or can you run the GP Moto air intake elbow instead? I ask because I plan to run brake cooling where the silencer would normally sit. |
| | #6 | |
IWSTI Addict since: Aug 2003 Trader Rating: (7) | Quote:
Here is a How to Install link. http://www.cobbforums.com/forums/ima...structions.pdf | |
| | #8 |
IWSTI Addict since: Apr 2006 Trader Rating: (0) | At the point that I finally go through with getting a downpipe and a tune, I really want to get an intake at the same time. I didn't want to get an intake that put the filter in the fender because I didn't want to have to dig deep every time I needed to maintain the filter. This looks like an excellent, complete solution for an under-the-hood intake system. I'm not highly knowledgeable on this subject, but it seems like this box plus some type of heat reflective material attached to the outside would be an excellent setup. I'll certainly keep the coolest vendor ever in mind when I get around to making my purchase. You guys have given me good service in the past. |
| | #9 |
IWSTI Addict since: Aug 2003 Trader Rating: (7) | From Cobb Highway Driving: COBB Intake no box: Max 124 degrees F, Avg. 91.6 degrees F COBB Intake with box: Max 108 degrees F, Avg. 74.9 degrees F Difference of: Max ~16 degrees F, Avg. ~16.7 degees F City Driving: COBB Intake no box: Max 149 degrees F, Avg. 117.4 degrees F COBB Intake with box: Max 111 degrees F, Avg. 87.5 degrees F Difference of: Max ~38 degrees F, Avg. ~29.9 degrees F Idle (~5 mins): COBB Intake no box: Max 149 degrees F, Avg. 133.5 degrees F COBB Intake with box: Max 113 degrees F, Avg. 99.2 degrees F Difference of: Max ~36 degrees F, Avg. ~34.3 degrees F |
| | #11 |
IWSTI Addict since: Aug 2003 Trader Rating: (7) | 2008 Sti is a couple months out. As they are doing some final test with it. This ad is not endorsed by this member. Please register or login to hide this ad. |
| Thread Tools | |
