Old 01-08-2008, 03:31 PM   #1
Car: 01 Subaru WRX STi Spec C
IWSTI Addict since: Aug 2005
Trader Rating: (14)
Default Comming Soon Peak Performance Pillowball Mounts
Comming soon from Peak Performance . Adjustable Upper Pillowball Mounts. These mounts are made from 8mm T6061 Aircraft Aluminum.
The rubber bushing is replaced with a pillow ball which eliminates the load input compliance, and reduces the change of alignment to improve the grip of the tire.
Anodized finishes provide maximum strength and durability against corrosion. Lightweight plates (22.oz) provide up to +/- 39mm of camber adjustment in the front and +/-32mm of camber adjustment in the rear. A perfect upgrade over the soft oem mounts.
Estimated Delivery Date
Mid March 2008
MSRP
Front-$220
Rear-$180
Gruppe-S is offline   Reply With Quote
Old 01-08-2008, 03:50 PM   #2
Car: 2006 WRX Wagon 6 Spd
Fav Mod: Chateau Montelana 2000 Cabernet Sauvignon
IWSTI Addict since: Oct 2006
Default Re: Comming Soon Peak Performance Pillowball Mounts
Are these for coilover applications only or will they work with OEM struts?
Schell is offline   Reply With Quote
Old 01-08-2008, 05:47 PM   #3
Trader Rating: (14)
We are currently testing the applications to ensure 100 compatibility with OE struts.
Old 01-10-2008, 06:10 PM   #4
Trader Rating: (14)
Bump Guys
