Old 01-07-2008, 12:02 PM   #1
Car: 427Vette/04E55AMG
Fav Mod: bc racing coilovers
IWSTI Addict since: Dec 2005
Trader Rating: (50)
Send a message via AIM to IMPORTIMAGE
Default New Product! Grimmspeed External Wastegate up pipe kit! look inside!
Import Image and GrimmSpeed would like to introduce the Grimmspeed External Wastegate Up Pipe with 38mm flange kit to you!
WHAT IS IT?
An external wastegate allows the exhaust gases to be diverted prior to
entering the turbo. Dumping the exhaust gas prior to the turbo helps with boost control, maintains boost longer in the rpm range, and extends the life of your turbo. Our pipe is fully built stainless steel EWG Up pipe and stainless steel dump tube for turbo Subarus. Monster thick SS flanges that will not warp. We have added a flex section which extends the life of the product and will lead to less exhaust leaks
because the pipe can flex vs. warping the flanges in a non-flex setup(inturn creating leaks).
WHY DO YOU NEED IT?
Reason for switching to an EWG setup includes:
1. Quicker turbo spool by allowing the exhaust gas to exit pre-turbo. There is alot of turbulence in the stock turbo at the internal wastegate so by moving the wastegate out of the turbo you get rid of this nasty turbulence thus improving the effiecency of the turbo as well.
2. More efficient wastegate design that has a bigger diameter than stock allowing for the exhaust gas to be released quicker.
3.Hold peak boost longer. This allows you to run a lower peak boost and increase HP at the same time.
Much larger than the stock internal wastegate!
No more boost creep...EVER!
GAINS?
Users should expect gains in the 15-40hp range when tuned for the EWG setup.
Another unique aspect of our package is that we include a bracket that holds your stock internal wastegate shut. This is great because you will no longer have to weld your turbo door shut which means you have no chance for leaks and you can revert back to stock anytime you want with no hassle.
PACKAGE CONTENTS
EWG Up Pipe
Dump Tube
Area1320 Bracket to hold stock wastegate closed(no more welding!)
5 Studs for Up Pipe
2 Allen head bolts for dump tube>wastegate
INCLUDES IWG BRACKET!!
What does that mean!? you no longer have to weld your stock turbos and you can return it to stock much easier! Not only is this a great product, its an innovation on the current market.
Gladly bringing you new products!
Josh Nahm
Import Image Racing Webstore
239 540 6385
IMPORTIMAGE is online now   Reply With Quote
Old 01-07-2008, 12:07 PM   #2
Car: 06 STi Spec C
Fav Mod: The STi experience
IWSTI Addict since: Oct 2006
Default Re: New Product! Grimmspeed External Wastegate up pipe kit! look inside!
Whoa whoa Josh! Why wasn't I informed about this earlier??? I've been looking for an affordable EWG kit for a while!
06SpecC is offline   Reply With Quote
Old 01-07-2008, 12:08 PM   #3
Car: 06 Subaru WRX STi
Fav Mod: Valentine 1
IWSTI Addict since: Sep 2007
Send a message via AIM to shan mann
priced shipped to 60106?
shan mann is offline   Reply With Quote
Old 01-07-2008, 12:09 PM   #4
^my bad, i didnt see the link to the webstore..
Old 01-07-2008, 12:18 PM   #5
Trader Rating: (50)
thanks guys...and sorry mr spec c...i didn't have any pics of it nor pricing til about 20 min ago...grimmspeed wanted me to handle the press release etc. SO there are some available now...and they are also making more. i'd say its a good bang for the buck, not to mention its all US made items, very high quality!
Old 01-12-2008, 08:37 AM   #6
Trader Rating: (50)
we did team up with tial and turbo concepts to make packages that include the ewg.
Old 01-12-2008, 08:48 AM   #7
Car: java black 04 sti
Fav Mod: steering rack bushings
IWSTI Addict since: Aug 2007
how much shipped to 21234
bigfuhrm is offline   Reply With Quote
Old 01-12-2008, 09:05 AM   #8
Car: 05 Subaru WRX STi
Fav Mod: Tein Flex coilovers
IWSTI Addict since: May 2007
will it fit the 4" txs dp?
FritoBandito is offline   Reply With Quote
Old 01-12-2008, 10:10 AM   #9
Trader Rating: (50)
yes grimmspeed says it fits bellmouth dp's
Old 01-12-2008, 10:27 AM   #10
H4N
Fav Mod: EWG, T 2'S
IWSTI Addict since: Mar 2005
looks like a nice piece, if i didnt have a ewg already i would be all over this.
H4N is offline   Reply With Quote
Old 01-16-2008, 07:12 AM   #11
Trader Rating: (50)
sure is nice! thanks!
