Old 11-09-2007, 01:54 PM   #1
AMS
Car: '05, '07 WRX STi
Fav Mod: BOOST!
IWSTI Addict since: Nov 2006
Send a message via AIM to AMS
Thumbs up AMS WRX/STi Timing Belt and Water Pump Special
For the holiday season we are offering a WRX/STi Timing Belt and Water Pump Special.
Normally $809 SPECIAL PRICE $699.99
Includes: ALL OEM Subaru parts.
- OEM Timing Belt
- OEM Tensioner
- OEM Water Pump
- Coolant & Labor
Water pump replacement is recommenced but not required. If you do not wish to replace the water pump the Special Price is $569.99
Subaru recommends replacing the timing belt every 60k miles under normal driving conditions in an unmodified vehicle. For modified vehicles and "spirited" driving styles this should be done more frequently.
Thanks,
Darius
AMS is offline   Reply With Quote
Old 11-09-2007, 02:22 PM   #2
IWSTI Addict since: Oct 2003
Default Re: AMS WRX/STi Timing Belt and Water Pump Special
just a little FYI, AFAIK the timing belt change interval on the OEM timing belt is 100k miles, the 60K miles that you are referencing I have only seen mentioned you have the AFTERMARKET STi Competition Timing Belt (p/n ST130284S000) which does not come on the STi's from the factory. I could be wrong, but I would double check your sources...
Scoobyless is offline   Reply With Quote
Old 11-09-2007, 02:56 PM   #3
Car: '07 WRB STi, '07 STi
Fav Mod: ;-)
IWSTI Addict since: Jul 2007
Send a message via AIM to spydersti
That's probably true (haven't checked my manual) but like it says on the bottom of the post...
"...under normal driving conditions in an unmodified vehicle. For modified vehicles and "spirited" driving styles this should be done more frequently."
For example...in my Audi 1.8T manual it says you're suppose to change the belt every 90k and it broke at 49.8k.... So don't go by what the manual says if you have any mods or if you like driving "hard".
spydersti is offline   Reply With Quote
Old 11-09-2007, 04:05 PM   #4
yea, i just figured i'd point out a bit of mis information, maybe doing it at 60k instead of 100k is a decent idea, but even that seems excessive to me, even on a modified car(as lightly as most people modify them, ie stage 2). They also seem to entertain the idea that it should be done at intervals less than 60k which is completely unnecessary for at least 95% of owners on this board.
Old 11-09-2007, 04:11 PM   #5
Authorized Member-Vendor
Fav Mod: Being IWSTI's Pawn Shop, lol
IWSTI Addict since: Sep 2004
Trader Rating: (52)
oooooooooooooohhhhhhhhhhh!!! callin' AMS out!!!
Crewchief is offline   Reply With Quote
Old 11-09-2007, 04:46 PM   #6
Car: 04 JBP STi
Fav Mod: All of them
IWSTI Addict since: Sep 2003
Actually he is correct. subaru recommends you check it at 30,60, and 90k and to replace if necessary. But they dont say to replace it untill 105k
although I have always been told 60,000 miles myself, and would actually stick to it because its cheap insurance. better than destroying your heads!!
I just did mine at 29k but thats because I had a failing idler pulley and did not want to chance anything else while I was in there
I also replaced the oil pump with a Cobb high flow pump on top of the water pump, thermostat, and every idler, tensioner, and kevlar timing belt!!
NewGenSTi is offline   Reply With Quote
