Closed Thread
Old 10-23-2007, 11:31 AM   #1
Car: 02 WRX
Fav Mod: FXT
IWSTI Addict since: Jun 2005
Send a message via AIM to Fine Line Imports
Default Introducing Fine Line Imports closed deck 2.5l motors
After extensive R&D Fine Line Imports is proud to introduce the first in their line of high performance Subaru motors. All Fine Line Imports motors are designed for maximum reliability and power handling while minimizing piston start up slap.
FLI STAGE 3 SHORT BLOCK
EJ25 "STI" Semi-closed Block (2.5L Displacement)
FLI closed decking process
Supertech / FLI forged pistons 100mm (8.2:1 compression ratio)
Billet Steel (4340) I-beam Connecting Rods
STI Forged Chromoly Crankshaft (79mm Stroke)
Professionally coated Rod and Main bearings
Heavy-Duty Chromoly Piston Pins
If you have any questions please let me know.
Ryan
Fine Line Imports
Fine Line Imports is offline
Old 10-23-2007, 07:02 PM   #2
Car: AW 05 STI
Fav Mod: Go fast ones
Default Re: Introducing Fine Line Imports closed deck 2.5l motors
What would said motor go for? Is it possible to just by the block, no crank/rods/pistons etc..?
-Mike
boostorlose is offline
Closed Thread
