Go Back   IWSTI.com: Subaru STI Forums > STi Technical Discussion > How-To / Install > Tools Discussion
Old 05-09-2008, 02:46 AM   #16
Titanium Member
Fav Mod: Modified Stock Heat Shield
Default Re: Recommendations for a FLOOR JACK
Originally Posted by xcritic View Post
I bought this one from harbor freight. I'm very pleased with it.
Harbor Freight Tools - Quality Tools at the Lowest Prices
I have a big floor jack and the Harbor Freight jack shown above. All I use is the Harbor Freight jack. It's very light and easy to get under the front of a lower than stock STi. I toss it in the trunk for autox events. Can't beat the value of this aluminum jack.
KarlSTI is online now   Reply With Quote
Old 05-24-2008, 03:31 PM   #17
Car: 2006 SGM WRX 6MT
One MAJOR concern between the 3 of those jacks listed is the actual weight.
Both Home Depot Jacks weigh in at almost 60 pounds.
The $95.00 Home Depot Jack: 55.3 POUNDS
The $165.00 Larin (Home Depot) 57 POUNDS
The $149.00 Harbor Freight Jack 37 POUNDS
The other things to consider:
The $95.00 Home Depot Jack: TOTAL LIFT HEIGHT: 18-1/4" (4" min)
The $165.00 Larin (Home Depot) TOTAL LIFT HEIGHT: 21-1/2" (3-3/4" min)
The $149.00 Harbor Freight Jack TOTAL LIFT HEIGHT:17-1/2" (3-1/2" min)
Team Scream is offline   Reply With Quote
Old 06-12-2008, 11:30 AM   #18
Car: 06 STi #86 STU
I've had the $29.99 2 1/4 ton craftsman jack from sears for about 4 years now. It works every time I need it. It isn't a large floor jack like the others. I guess they call it a trolley jack. At any rate, its been reliable, effective and economical. However, I am getting one of the nice aluminum ones (with a long handle) now that I have a house and a garage.
Rosco46 is offline   Reply With Quote
Old 06-12-2008, 11:33 AM   #19
Enginerd
Car: The Spaze Mobile
Fav Mod: Tuning
Originally Posted by amg destroyer View Post
I have a 3 ton steel Craftsman jack that I got from Sears in a combo pack. It included a pair of 3 ton jack stands, the jack, and a creeper for like $140 or something.
I bought the same thing back in 2001. It still works fine, but I have to rebuild the jack soon. It's starting to slowly drop when a lot of weight is on it. The handle actually starts to creep upwards as the jack lowers. I almost totally killed my front bumper one time.
Old 06-12-2008, 11:53 AM   #20
Car: PSM 05 WRX STi
Fav Mod: Coming Soon : Access Port, Cobb TBE, and everything like the rest.
Make sure you buy one with dual pistons, it'll last longer, I believe.
dreamvang is offline   Reply With Quote
Old 06-22-2008, 01:00 PM   #21
Fav Mod: Proper Alignment
I have the HF Aluminum race jack and it has held up well for the price. My only complaint is it has a limited lift range if you really need to work on the car.
It is perfect for taking to an autox for changing tires though.
UberWagon is offline   Reply With Quote
Old 06-22-2008, 07:33 PM   #22
Trader Rating: (13)
Harbor Freight blue aluminum racing jack here as well
blindfold is online now   Reply With Quote
Old 06-22-2008, 09:55 PM   #23
Black Dragon STI
Car: 07 OBP STi 03WRB WRX
Fav Mod: My whole suspension
I use this one:
JEGS 80034 - JEGS 2-Ton Aluminum Floor Jack - JEGS
It works great. One thing that rocks is that it has a fast-lift feature that gets it up to the car in just a pump or two. Weight and lift height are similar to the harbor freight, but there are a lot of little things (like the fast lift) that set this apart. It's pricey, but good. Considering how often I use it (two cars I do all the work on, plus tire swaps at rallycross events), I'm glad I got a good quality jack.
