Go Back   IWSTI.com: Subaru STI Forums > STi Technical Discussion > How-To / Install > Tools Discussion
Old 01-05-2008, 01:07 AM   #1
Car: BLOBEYE SYNDICATE ST
Fav Mod: N-E thing JDM
Question list your methods of removing stripped nuts/bolts..
Well, I was doing my OEM bumper beam and got 5 out of the 6 nuts and bolts off.I got to the last bolt and the nut got stripped using my 14mm socket. So I going to try the gator grip..If that doesnt work, then I just have to dremmel it. So I was wondering what are your methods of removing stripped bolts or nuts.
T.I.A.
twilight_samurai is offline   Reply With Quote
Old 01-05-2008, 01:11 AM   #2
Enginerd
Car: The Spaze Mobile
Fav Mod: Tuning
Default Re: list your methods of removing stripped nuts/bolts..
I just drill an appropriate sized hole and get a reverse bit in it.
But I think you're describing 'rounding' of the hex head (since you mentioned the Gator Grip) . Get a frickn set of vice grips on that ***** and relieve some life stress. Then replace.
Old 01-05-2008, 08:58 AM   #3
Send a message via AIM to nice-rice
I had a problem with one of the nuts on the bumper beam too. My friend brought over a little set of sockets that were all jagged on the inside, forgot what they were called. But it took off with ease, I was impressed.
nice-rice is offline   Reply With Quote
Old 01-05-2008, 09:27 AM   #4
Car: 05 Blue/Gold
Fav Mod: Blinker Fluid and Piston Return Springs
Craftsmen makes a set called Bolt outs: here.
I've used them and they work pretty well. I had to use them on the mounts for the front swaybar. I found it helped to set the socket on the bolt, then beat on it with a hammer a bit so that the socket really bites into the nut.
IlliniSTi is offline   Reply With Quote
Old 01-05-2008, 10:33 AM   #5
killer ants in your pants
Trader Rating: (21)
all this nut banging and biting is making me cringe!
I like to heat up my nuts and bolts with a torch. :wink: It does work very well on strut bolts that are seized. Just don't heat up the strut!
snorky is online now   Reply With Quote
Old 01-06-2008, 08:38 AM   #6
Subie Love Subie Love
Platinum SEMA 2007 Sponsor
HSPN Platinum Lifetime Member
I get out the air tools.
Sideoiler is offline   Reply With Quote
Old 01-06-2008, 09:54 AM   #7
Car: '07 SWP STi
Fav Mod: Limited Wing!
Send a message via AIM to Kickstand
Heat works well if its seized up, if its rounded , its either vice grips or bolt outs. If all else fails, die grinder and a cutoff wheel. Sparks FTW!!!
Kickstand is offline   Reply With Quote
Old 01-07-2008, 06:13 PM   #8
Support Our Sponsors
i press my sloping forehead against it and think... r e a l... h a r d...
Old 02-10-2008, 08:43 PM   #9
Hey guys,
Sorry for the late update.. As for the totally rounded nut, it is demolished by using cut off wheel, chiseling it, and the craftsman stripped nut socket remover.. Heres a pic of it and sorry its blurry but took it with my cam phone..Any suggestions on how I proceed now.. Right now im just stressin.. I need help!!! Thanks for listening guys..
before:
After:
Old 02-10-2008, 10:05 PM   #10
The Stig II
Fav Mod: Meth protune 323+/380+
Soak em in penetrating oil for a while....then heat...heat...heat...then use a large vice grip and work free.
Works for me every time.
jnprn2003 is offline   Reply With Quote
Old 02-10-2008, 10:09 PM   #11
Fav Mod: CAR LIFT & Protune!
Order Here!
How to Remove a Stripped Screw - wikiHow
Ace - Ace Tree: Tools: Hand Tools: Sockets & Wrenches: Specialty Sockets: Ace Extractor Damaged Nut/Bolt Remover (XSB.200A)
Old 02-14-2008, 08:24 PM   #12
thanks guys, ill have to get back to it during the weekends..Ill let you know how it goes..
thanks again!!!!
