Old 08-16-2007, 07:07 PM   #1
Car: 05 OBP STI
Default Repaired tire speed?
I had a nail in the center of my stock tire rear passenger side and I patched it and it looks ok. Since then I don’t feel confident of doing 140 + because I don’t think the tire will hold the pressure. What do you guys think. Is it safe to do those speeds with a repaired tire?
wpwm020 is offline   Reply With Quote
Old 08-16-2007, 07:23 PM   #2
Car: Silver 05 WRX STi
Send a message via Yahoo to import111
Default Re: Repaired tire speed?
Not that I condone that kind of driving on public roads, but I did 140mph on a plugged tire and did a track day on a road course all day with that plugged tire too. Still using the same tire, I have not had a problem with it.
import111 is offline   Reply With Quote
Old 08-16-2007, 07:30 PM   #3
Car: 04 SUBARU WRX sti
Fav Mod: JDM FOGS
i worked in a tire shop for about a year at mercedes. You can put up to 3 patches in one tire without affecting the speed rating. THe only thing that i suggest is that if you used one of the plugs taht you push in from the outside you should get it changes to a two piece patch from the inside. WIth the kind that you push in from the outside it allows for moisture to enter into the tire/ wheel assembly. i have seen this eat the paint off of an entire inside of a wheel on many occasions. just my .02.
