Old 08-13-2007, 10:53 AM   #1
Indiatr0n in yo IWDPL
Fav Mod: Brum Brum
2007 Postwhore King
Exclamation TEST FIT: 17" x 8.5" +51 Prodrive GC-06H w/ 255/40-17 RT-615s on Pinks
Car: nandanrp's 2005 WRX STi, stock fenders
Wheels: Boondocksaint's Prodrive GC-06H 17" x 8.5" +51 in British Gold
Tires: Falken Azenis RT-615 255/40-17
Suspension: JDM STi Pinks, Prodrive bumpstops, RCE lowering front camber plates
We wanted to know if this setup would rub with stock (unrolled) fenders. Short answer: yes, it will rub in the rear, under load*
*Long answer: Depends on rear camber. I'm not sure how much rear camber I could run with this setup before I rub on the spring perch, but right now we know that -1.3 on my driver's side rubbed more than the -1.8 on the passenger side (I do not have rear camber bolts yet).
To test, we swapped the wheels over, and put painter's tape on the rear fender lip. If we saw marks on it, we knew there was rubbing.
Not only did we see marks on the tape, the driver's side (-1.3) rubbed hard enough at one point that the tape was stamped with a marking from the fender We also felt it touch the fender when I hit a dip at some speed while cornering... (I drove that section of road in both directions, and felt it both times).
Pictures:
I'll have a few more pictures of my car with the wheels on in my journal, but I figured I'd keep the pictures in this thread mostly on the tech side
Thanks to boondocksaint for risking his wheels on my car (He was about 50% sure I wouldn't put up a fight to keep them on ).
Old 08-13-2007, 10:57 AM   #2
Wheel33tist Whore
Default Re: TEST FIT: 17" x 8.5" +51 Prodrive GC-06H w/ 255/40-17 RT-615s on Pinks
nice test guys.
T3h_Clap is online now   Reply With Quote
Old 08-13-2007, 10:58 AM   #3
Fav Mod: Brum Brum
2007 Postwhore King
So what kind of camber could be run in the rear so that there's no rub on the fender or the perch?
Old 08-13-2007, 11:00 AM   #4
HowTo Contributor
Car: 2008 DGM (BBS+Navi)
Fav Mod: stock FTL?
damn that car looks sexy with those rims on it.
put the stock springs back in!
form > function!
kts262 is online now   Reply With Quote
Old 08-13-2007, 11:01 AM   #5
Wheel33tist Whore
i'll run some #s but i'd say you could get away with -1.9 or so in the rear both sides without issue.
or you could take a dremel to the fender lip and run -1.7 or so.
it's good to know the tape worked
Old 08-13-2007, 11:09 AM   #6
Fav Mod: Brum Brum
2007 Postwhore King
form > function!
Haha! Yeah it looked better than I thought it would. I've liked the GC-06Hs for a while now, but I thought *my* car would look better with more spokes. I was wrong
Interesting.
Sounds like he'll be just fine if he goes the coilover route then. Probably won't need fender work even
Old 08-13-2007, 11:41 AM   #7
Reasonable
Fav Mod: correct grammar
As long as it handles like I want it to, I don't mind rolling fenders. Not interested in cutting fenders, though.
GC-06h > RE30
My opinion, of course, and they look better in gold on black than they would "British Black" on black. Also my opinion.
Old 08-13-2007, 12:14 PM   #8
Car: Silver 05 WRX STi
Send a message via Yahoo to import111
That is very strange that you had rubbing with that setup. I have about as close to that setup as possible....
17x8.5 +50 offset Wheels with 255/40/17 RT615's
-1.8 / -1.4 F/R camber
Tein Flex coilovers
I get no rubbing anywhere and my car is pretty low. It is close inh the rear, but I have never rubbed once. My +50 offset sticks out 1mm more than your +51 offset. Not sure how you are rubbing.
import111 is offline   Reply With Quote
Old 08-13-2007, 12:16 PM   #9
Reasonable
Tein Flex coilovers
The only apparent difference is the suspension. Have you done any fender mods?
Old 08-13-2007, 12:21 PM   #10
Fav Mod: Brum Brum
2007 Postwhore King
Well, the flex probably has a higher spring rate than the Pinks. If you look at the pictures you can see there's plenty of gap when the car is parked (i.e. it's not tucked right now...). Upon compression, it rubs.
If your teins are stiff enough, it might not rub. Paging Dr. .
Old 08-13-2007, 12:24 PM   #11
Wheel33tist Whore
Tein Flex coilovers
i have a feeling your 8k rear springs have something to do with it not rubbing
Old 08-13-2007, 12:34 PM   #12
Car: 04 WRB
Fav Mod: Greddy TI-C
god those are sexy! sorry to not contribute to the thread... but damn..
Old 08-13-2007, 12:35 PM   #13
Fav Mod: Brum Brum
2007 Postwhore King
It's the 05 FTW that really does it for them huh?
IBBoony.
Old 08-13-2007, 12:37 PM   #14
Reasonable
IBBoony.
My wheels make your car look good.
IANan.
Old 08-13-2007, 06:00 PM   #15
Car: '05 STi
Fav Mod: Britax Roundabout
That looks awesome Nan. Just take them, we'll fiddle with the fenders later. I agree - it's the '05 that does it.
Andy STI is offline   Reply With Quote
