Old 06-18-2007, 07:11 PM   #1
Car: Silver 04 STi
Fav Mod: Coilovers
Default 235's or 245's??
I have a set of SSR Professor SP1's 18x8.5 which I previously had 225/40/18 Michelin Pilot Sports. This size was too skinny for the 8.5 inch wheel so I am looking for something wider. Should I go with 235/40/18 or 245/40/18? I want to keep the sidewall pretty small and I have heard that the sidewall on 245/40/18's is a little big but I like the idea of a wider tire. Also does anyone know if Nitto NT555's are a good tire?
Agati'sSTi is offline   Reply With Quote
Old 06-18-2007, 07:20 PM   #2
Wheel33tist Whore
Default Re: 235's or 245's??
get a 235/40 in either an RT615, RE01r, AD07 or RS2
the NT555s are not as good as any listed above.
Old 06-19-2007, 05:41 AM   #3
Car: Silver 04 STi
Fav Mod: Coilovers
Anyone else have an opinion?
Old 06-19-2007, 05:43 AM   #4
Wheel33tist Whore
nope.
j/k, i'm sure someone will chime in.
Old 06-19-2007, 05:45 AM   #5
Authorized Member-Vendor
Fav Mod: Being IWSTI's Pawn Shop, lol
Trader Rating: (52)
Had those wheels on my last sti, good pick! Now got Gram lights 18x8.5 57F's on the current STi. I say run a 255/35/18 like myself. You may rub, but i didnt. You can always roll the fenders or kick in some camber if you do. Also I'd listen to T3h Clap, he's probably our most knowledgeable wheel/tire guy on this forum.
Crewchief is offline   Reply With Quote
Old 06-19-2007, 05:48 AM   #6
Car: 2004.5 STi
Fav Mod: Driving School
well a 235/40's sidewall will be 1/5" bigger than your current 225/40.
The 245/40 will be 2/5" bigger so your choice there.
Id agree with Clap about tires though - go with a known performer.
Bridgestone RE01R, Falken RT615 or Kumho MX if they come in that size. They are cheap.
TR11 is offline   Reply With Quote
Old 06-19-2007, 05:51 AM   #7
Wheel33tist Whore
issue with a 255/35 is there are not alot of options, and no "True" performers come in that size.
Old 06-19-2007, 06:02 AM   #8
Car: 06 Subaru WRX STI
Send a message via AIM to dukenukem
How big is the performance difference between 245/45 and 245/40 for RE01R or the likes ? Sorry to take it ot ..
dukenukem is offline   Reply With Quote
Old 06-19-2007, 06:07 AM   #9
Wheel33tist Whore
slower response, higher speed in a given gear.
traction wise would be less in theory since the 45 has more flex due to the higher sidewall.
245/40 RE01Rs are awesome, I'm tempted to get a setup to run STU.
Old 06-19-2007, 06:12 AM   #10
Car: Silver 04 EDM STi
Fav Mod: none yet :)
First off, sorry that my first post is a hijack, thousand appologies, you can slap me if you come over to Belgium
Would I be able to run 245/40's on an 18x8.5 +44 without any other adjustments ?
roydriessens is offline   Reply With Quote
Old 06-19-2007, 06:27 AM   #11
Car: 05 AW Subaru WRX STi
im runnin 245x35s on my 18x8.5" +45 advans. only 0.2" shorter overall than the stock tires.
b00st3d is offline   Reply With Quote
Old 06-19-2007, 06:29 AM   #12
Wheel33tist Whore
it really depends on your suspension setup.
that tire is .7" taller than stock and cause issues rubbing in the front if you're too low.
Old 06-19-2007, 07:09 AM   #13
Car: Silver 04 STi
Fav Mod: Coilovers
So I would not be able to go very low with a 245/40/18 RT 615? Because I like to have my ride height pretty low, wheel gap is my enemy.
Old 06-19-2007, 09:01 AM   #14
Car: 04 subaru sti
Fav Mod: 35r turbo kit
run a 245 35 18, heres my car ,take a look
18 x 8.5 re30's with a toyo t1r 245/35/18
will12345 is offline   Reply With Quote
Old 06-19-2007, 09:51 AM   #15
Wheel33tist Whore
are you running the +44mm offset?
do you have any more shots.
Also, i'm very unhappy with the performance of my T1Rs.
