Old 03-27-2008, 12:23 AM   #121
Car: 05 Subaru Wrx STI
Fav Mod: Greddy Tic
Default Re: Bridgestone Potenza RE-01R
I have an 05 sti with stock bbs rims. What tire size should i get 245/45/17, 245/40/17 or do i get 225/45/17? For the 01r's. My car is not lowered and not planing on it. If so why? thanks
harout18 is offline   Reply With Quote
Old 03-27-2008, 05:22 AM   #122
Why not look at the measurement data for the tire to select one that has close to the same diameter, and go from there?
mx_9 is offline   Reply With Quote
Old 03-27-2008, 08:30 PM   #123
Car: '05 CGM STi
Fav Mod: Helix Catted DP
Do you plan on racing? If so, I would go with the 245/40/17, gives you a wider contact patch, yet keeps close to the stock diameter..
STEye is offline   Reply With Quote
Old 03-27-2008, 09:13 PM   #124
Iron Fisted
Fav Mod: Sparco seat
I have the 245/40/17 on my stockers and it is perfect. you won't regret it.
Old 03-27-2008, 09:37 PM   #125
Car: 06 STI
Damn the 245/40/17's are going for 205 a piece now on tirerack? How would the 235/40/17's which are 30 bucks cheaper fare? Isn't that the JDM size?
XandeR803 is offline   Reply With Quote
Old 03-28-2008, 12:48 AM   #126
Fav Mod: Greddy Tic
thanks for the feed back guys. I was just wondering what is the big difference between the 245/40/17 and the 225/45/17? What is the advantage of having the 245/40/17? thanks agian guys
Old 03-28-2008, 05:47 AM   #127
Fav Mod: so far? RCE T2s
this is a tricky question and physics won't lead one to any enlightenment. My theory is that a wider tire disperses peak instantaneous loads when loaded to the limit at the microscopic scale. It doesn't really matter what theory you believe or how much mumbly-gook you throw at it, the bottom line and the benefit of wider tires is simply, wider tires will generate more peak gs.
Old 03-30-2008, 07:40 PM   #128
Car: 05' STI
Fav Mod: Defi gauges, or TXS TBE or JDM sidemarkers...arg!
Arrow Re: Bridgestone Potenza RE-01R
Looks like they are on sale again at 160 dollars or so... unless I am looking at different ones?
Question: What are the stock sti tire's size?
And this is silly but what do the numbers mean as far as :
245/40/17
225/45/17
And why in the above does first number bigger but the second number is smaller in the first figure compared to the second figure of a smaller first number and larger second number?
I know that the 17 is for the wheel size of 17" but what about the rest?
Thanks,
-Nigel
NewShockerGuy is offline   Reply With Quote
Old 03-30-2008, 08:03 PM   #129
Car: '05
Fav Mod: AP
this might help some of you:
Example: 185/60R14 85H or 185/60HR14
185mm x .60=111mm
111mm x 2=222mm
222mm + 355.6mm(14")= 577.6mm or 22.74"
The first number is the width of the tire in millimeters, measured from sidewall to sidewall. To convert to inches, divide by 25.4 In the example above, the width is 185mm or 7.28".
The second number is the aspect ratio. This is a ratio of sidewall height to width. In the example above, the tire is 7.28" wide, multiply that by the aspect ratio to find the height of one sidewall. In this case, 185x0.60=111mm or 7.28"x0.60=4.36".
The last number is the diameter of the wheel in inches.
dannyblaze_07 is offline   Reply With Quote
Old 03-31-2008, 05:10 AM   #130
Wheel33tist Whore
to be simple
for a 225/45/17
225 = Section width (this isn't a 100% accurate number, not all 225s are 225)
45 = The Profile in % of the Section width. (this can get complicated but for simplicty sake lets say it's just 45% of 225 (for this example)).
17 = Wheel Diameter
i can explain further if you're still confused.
T3h_Clap is online now   Reply With Quote
Old 03-31-2008, 11:30 AM   #131
Car: '05 Subaru WRX STi
so whats the advantage of a 245/40/17 vs. 245/45/17?????? just wondering why the 45's are $60 less than the 40's???? (Tire Rack)
05_STi_WRB is offline   Reply With Quote
Old 03-31-2008, 11:33 AM   #132
Wheel33tist Whore
the 245/45/17 is taller by nearly .7"s this can cause rubbing issues on some suspensions and wheel sizes.
the 245/40/17 is closer to stock diameter.
the 245/40/17 with the shorter sidewall will also have better steering response (in theory).
Old 03-31-2008, 11:43 AM   #133
^^^^thanks for the quick answer.....
Old 03-31-2008, 11:51 AM   #134
Wheel33tist Whore
no problem.
Old 03-31-2008, 07:59 PM   #135
Fav Mod: Greddy Tic
will going from a 225/45/17 (stock) to a 245/40/17 (re01r) mess with the odomiter at all?
