IWSTI.com: Subaru STI Forum
Go Back   IWSTI.com: Subaru STI Forum > STi Technical Discussion > Tires & Wheels
Old 06-07-2007, 08:53 PM   #91
Car: '06 STI
Fav Mod: air freshener!!!
Default Re: Bridgestone Potenza RE-01R
^^ I bet you can, they seem to wear well.
FWIW, a stack of Hoosier cup tires in 245-40-17 are just over an inch taller than a stack of Hoosier R6 in the same size. The cup tires are spec tires so they just have to mark them in the legal size and then make them however they want. It's a one tire brand class anyway...
Old 06-12-2007, 02:49 AM   #92
STI Guru
Fav Mod: grip.
went to the shop to check out my re01's last night... i cant wait to take the car out and see how they feel... ill post impressions tonite or tomorrow
Old 06-14-2007, 03:55 AM   #93
STI Guru
Fav Mod: grip.
check my member journal for a mini review
Old 06-15-2007, 11:18 AM   #94
Car: '07 STI Limited
Very informative thread.
Anyways, I have 17x8" rims on the '07 Limited (stock). Am I really better off going with the 245/40/17 than the 225/45/17 for the RE-01R's? Most people here seem to be going with the 245's on the 8" rims. Any reason why? I know that wider tires are cooler and "higher performace," but is there really that much of a difference (performance wise)?
haasSTI is offline   Reply With Quote
Old 06-15-2007, 11:23 AM   #95
Car: 08 STi, SSM
some people are sticklers for contact patch size, tread width from RE070 to RE01R goes down by 0.4" on the same 225/45/17 size. In my opinion, bigger contact patch FTW. That's why people like the 245s
Old 06-15-2007, 12:04 PM   #96
Car: '06 STI
225 with their vertical sidewalls will ride harsher, have quicker turn in, but less total grip.
245 with their canted sidewalls will ride smoother, have less immediate feel on turn in, but have more total traction.
The above assumes that all else is equal.
Old 06-17-2007, 10:29 AM   #97
STI Guru
Fav Mod: grip.
just as an fyi in case anyone was wondering, im running the 245/40/17s on stock bbs's ... rce springs/ohlins struts... no rubbing, just lots and lots of grip. i had these on pocono yesterday and they performed extremely well.
Old 06-21-2007, 02:06 AM   #98
Fav Mod: GT35R
So 17x8 will fit with 245/40/17 right? I just gonna order a set pretty soon.
Anyone know how long this special price will end?
caballero_sti is offline   Reply With Quote
Old 06-21-2007, 02:12 AM   #99
STI Guru
Fav Mod: grip.
what suspension? and which wheels?
im currently running 245/40/17 on the stock 8" bbs's with the RCE/ohlins combo, ive pushed it on the track and street and it does not rub at all
Old 06-21-2007, 05:46 AM   #100
Car: 05 WRB STi
Fav Mod: Pro Tune
I just put 245/45/17 on the stock BBS'. They feel awesome! A lot quieter and real grippy. Got the special deal on tirerack and had them shipped to my door for $642.58
ilikepie is offline   Reply With Quote
Old 06-21-2007, 01:45 PM   #101
Car: 04 PSM STi
Woohoo. Just received my $100 SCCA rebate from Bridgestone. Total price after rebate for the set of 245/40-17s shipped = $520.
After a month of driving, I can honestly say that these grip better than the RE070s. I don't miss the sidewall stiffness at all, since these feel so much better and more compliant.
wi77iam is offline   Reply With Quote
Old 06-24-2007, 06:13 PM   #102
Did you mount these on the stock 7.5" rims? I want to go wider than the stock 225's but I have the stock 7.5" rims.
na-STi is offline   Reply With Quote
Old 06-24-2007, 06:28 PM   #103
Car: 04 PSM STi
Nope. Mounted on my 8" Rota Torques. Some people have said that they will be OK on the 7.5" rims, but the specs on Tirerack say that 8" is minimum. You could go with the 245/45, which is the size I was going to get initially.
Old 06-28-2007, 09:43 PM   #104
HowTo Contributor
Car: 06 Aspen White STI
Send a message via AIM to Shakes Send a message via Yahoo to Shakes
Just got my 245/40/17's mounted on my 06. Can't compliment on the stickieness yet since they only have 30 miles on em, but I can comment about noise and comfort.
Drive over one rumble strip or strip of lane divider bumps and you will smile.
Shakes is offline   Reply With Quote
Old 07-09-2007, 12:00 PM   #105
Car: 05 Subaru WRX STi
Fav Mod: Pioneer D3
Where is the best price on the 245/40/17's? Tirerack is $165? Thanks...I need new tires bad! I have a 33 hour road trip comming up!
AGUSTA is offline   Reply With Quote
