Old 06-13-2008, 05:35 PM   #181
Car: 2005 Aspen White STi
Fav Mod: T-Tops
Default Re: Bridgestone Potenza RE-01R
Originally Posted by SAMMYBOY View Post
I read some very good reviews on these tires as a good replacement for the noisy RE070's, so I had them installed on my '04 STi.
They are definitely more quite, with nice steering feel. I am still breaking them in, so the verdict on road holding and braking is pending, but so far I like the way the car drives and I am enjoying the engine noise too!
The only problem is that they look thinner than the RE 070's, although they are the same size (225 45 17)!
Now, I have mixed feelings about this and thinking maybe I should I have gotten a bigger size!
Any ideas or suggestions? My rims are the original 7.5" BBS.
Best handling performance street tire available. Period.
SLY STi is offline   Reply With Quote
Old 06-13-2008, 06:02 PM   #182
DCH
Fav Mod: Q-Rack!
Send a message via AIM to DCH
Just ordered the 245/40/17. Install will be Monday! Can't wait!
DCH is offline   Reply With Quote
Old 07-02-2008, 06:35 PM   #183
Car: 06 STi
Fav Mod: boost creep!!!!!
What pressures should I run on my 255/35's on street?
sti-06 is offline   Reply With Quote
Old 07-03-2008, 12:08 PM   #184
Car: ITS URABUS
Fav Mod: Pagids
I have about 3k on these babys and they are hands down the best tyre i have ever used.
2slow2curious is offline   Reply With Quote
Old 07-03-2008, 01:35 PM   #185
Originally Posted by Boxer View Post
235/45/17
I went with these because the BBS on my '04 are 7.5" wide and 245 are too wide for that rim width. If you have 8"+ rims, by all means go with 245.
Have you had a chance yet to run an odometer check? I'm wondering if this size will correct the OEM speedomoter which reads attrociously high...
Old 07-03-2008, 04:25 PM   #186
Car: Silver 05 WRX STI
Fav Mod: the back roads
^^check out this site you can punch the numbers in and they will tell you how much it changes the speed. I was looking at it the other night for the same reason!
Tire Dimensions Made Simple - Discount Tire Co.
mstinger2003 is online now   Reply With Quote
Old 07-03-2008, 06:56 PM   #187
Hmmm...only 1 mph at 70...that isnt near enough.
