IWSTI.com: Subaru STI Forum
Go Back   IWSTI.com: Subaru STI Forum > STi Technical Discussion > Tires & Wheels
Old 04-01-2008, 05:49 AM   #136
Wheel33tist Whore
Default Re: Bridgestone Potenza RE-01R
not enough to matter.
you're talking 10 miles over the 25000.
T3h_Clap is online now   Reply With Quote
Old 04-01-2008, 08:46 AM   #137
Car: '05 Subaru WRX STi
so a 255/40-17 would be almost a perfect match to the stock 225/45-17, but how will they fit on our stock 8 inch wheels? my car is at stock ride height so there sould not be any rubbing issues??? maybe???
Tire Size Comparison
Specification Sidewall Radius Diameter Circumference Revs/Mile Difference
225/45-17 4.0in 12.5in 25.0in 78.5in 808 0.0%
245/45-17 4.3in 12.8in 25.7in 80.7in 785 2.8%
245/40-17 3.9in 12.4in 24.7in 77.6in 816 -1.0%
255/40-17 4.0in 12.5in 25.0in 78.6in 806 0.2%
05_STi_WRB is offline   Reply With Quote
Old 04-01-2008, 09:24 AM   #138
Wheel33tist Whore
How Wide of Tire can I Run on my 2005+ Subaru Impreza WRX STi on Stock Wheels? » t3h_Clap’s Wheel33tist Blog
Old 04-01-2008, 03:13 PM   #139
Car: 07 Sti SWP
Cool Re: Bridgestone Potenza RE-01R
Still waiting for a good pic of 255/40/17 on stock BBS's.
wrinklefree is offline   Reply With Quote
Old 04-02-2008, 05:02 AM   #140
Fav Mod: Whiteline Sways
The 245/40/17s are now $205 each at tire rack. Is there any place to get them cheaper? I'd pull the trigger if I could get them for ~$150 a tire.
Wolverine 250R is offline   Reply With Quote
Old 04-02-2008, 05:10 AM   #141
Car: 05 Black STi
Edge racing does 196 per tire.. best I've seen
briancl is offline   Reply With Quote
Old 04-02-2008, 07:04 AM   #142
Car: Blue 06 Sti
Send a message via AIM to santacruz02
Very informative thread
Does anyone have pictures comparing
245/45/17 to 245/40/17?
santacruz02 is offline   Reply With Quote
Old 04-02-2008, 04:06 PM   #143
Car: 05' STI
Fav Mod: Defi gauges, or TXS TBE or JDM sidemarkers...arg!
Arrow Re: Bridgestone Potenza RE-01R
Originally Posted by T3h_Clap View Post
the 245/45/17 is taller by nearly .7"s this can cause rubbing issues on some suspensions and wheel sizes.
the 245/40/17 is closer to stock diameter.
the 245/40/17 with the shorter sidewall will also have better steering response (in theory).
Why would you want a taller tire?
I can understand "wider" but taller unless I am in a truck I can't see value in it for an sti?
But I could be looking at this wrong...
-Nigel
NewShockerGuy is offline   Reply With Quote
Old 04-02-2008, 04:07 PM   #144
Car: 05' STI
+2 to that!
-Nigel
Old 04-02-2008, 07:05 PM   #145
Wheel33tist Whore
-Nigel
the STi isn't short on tq or pwr so a taller tire doesn't really slow the car down and it allows for a higher top speed in each gear.
which is good for Autox not always so good for street or fitment issues
Old 04-17-2008, 08:51 AM   #146
Car: WRB 2005 STi
Fav Mod: SPT exhaust
I am considering the same two sizes. I have read that one benefit of the 245/45 is that it is closer to the 235/45s run on the JDM cars. While a 245/45 is .7" larger than the 225/45 USDM tire it's only .3" larger than than the 23/45. I have read that this might help improve the accuracy of the USDM speedo. What do you guys think?
I am concerned about using the taller tire with my RCE Yellow springs with the stock 8" BBS's. Is anybody out there running the 245/45s with the these springs?
mn_sti is offline   Reply With Quote
Old 04-23-2008, 10:17 AM   #147
Car: 2004 STi & 2005 LGT
Fav Mod: Track Time
Any fittment issues on 17 wheels?
I'm having a set of RE-01R 245/40x17s mounted on 17x8 wheels this week for my 04 STi - stock suspension.
Anyone with this set up have any fittment issues, IE: rubbing, etc?
TIA.
Peace,
Curtis
TurbeauxREX is offline   Reply With Quote
Old 04-23-2008, 10:19 AM   #148
Wheel33tist Whore
you may rub in the rear depending on the offset of the wheel.
the 04s really need a fender roll.
Old 04-23-2008, 10:32 AM   #149
Fav Mod: Track Time
Thanks. I'm running 17x8 rota torques. I think the offset is 48mm. Stock suspension w/78k miles. Might be time to pony up for some shocks and springs.
Old 04-23-2008, 10:33 AM   #150
Wheel33tist Whore
springs wont help.
you need to roll your fenders.
