Old 03-31-2004, 07:54 AM   #16
IWSTI Addict since: Feb 2004
Send a message via AIM to ingrahamm
Default STI Article.
your local SCCA region is wrong unless they don't use the National rules.
The STi runs in A stock and E street prepared (for this year anyway). This can be readily verified by reading a rule book or looking here: http://moutons.org/sccasolo/ where there is an unofficial reprint of the rules.
matt
ingrahamm is offline   Reply With Quote
Old 03-31-2004, 08:58 AM   #17
IWSTI Addict since: Jun 2003
Hmm, ASP does not make sense to me. It should be either ESP or SM.
FT@SGP is offline   Reply With Quote
Old 04-01-2004, 08:43 AM   #18
Car: 97 gc8
IWSTI Addict since: Sep 2003
matt
thank you for this information,very helpful
dave/mspt
M.S.P.T is offline   Reply With Quote
Old 04-28-2004, 03:03 AM   #19
IWSTI Addict since: Dec 2003
Default Photochopped
The kumho 710s have been banned from SCCA. I've been running the 245x45x17 victoracers in A stock. They've been working out great for autoxing, but recently corded a pair last week during my 2nd 30 minute track session in Pahrump, NV (http://www.bragg-smith.com/track/). Awsome track! BTW, I admit to running them very hard during back-to-back track sessions and would have corded just about any other R-compound.
I'm thinking about using the victoracers just for autoxing and going with
something a little harder and tougher for track racing like maybe the Falken Azenis. 245x45 is working great for me and I'll probably stick to the size. no rubbing with 48mm offset wheels.
I'm getting a lot of roll-over on the front tires with cold air pressure at
38psi. and camber max'ed at negative setting. Anyone else expierencing this rollover? I've just ordered the COBB front swaybar to see if it helps at
all. keep'in it all A-stock legal for the time being...
I took a bunch of pics and a couple in-cam race flicks. Take a look:
http://68.8.161.144:81/friends/pahrump/html/index.htm
here's a pic of the corded victoracer, got decent wear, but badly corded the outside:
flyin-sti is offline   Reply With Quote
Old 04-28-2004, 08:47 AM   #20
Car: 2004 Subaru STi
Fav Mod: race tires
IWSTI Addict since: Feb 2003
Originally Posted by FT@SGP
Steering rack bushings not allowed in AS to my knowledge [...]
Do you know if they're allowed in street prepared? A lot of people recommend these in general, but I had the impression they were not legal for SP, but now I can't seem to find any info one way or the other. In my case I really need them to be legal. I suspect they are not just because I don't see anything about them in the rules, but maybe they are just another form of "suspension bushing" as referenced in 15.8.C.
I've heard Victoracers are not the best at the track. They get too hot too fast. Try something like a Toyo RA-1 if you want an R compound. I've been running a set of 235/40 RA1s and they work quite well -- cost is about $160-180 each. They're OK for autocross as well, but they're not as sticky as the Kumhos. On the other hand I just set FTD at one event and 2nd after the AM car at the previous event running an ESP STi on RA-1s, so they're not that bad. New alignment and camber plates meant some crazy fast turn-in! The Miata driver who got 2nd in PAX behind me on both days now wants a much closer look at my setup...
WRX_Mundi is offline   Reply With Quote
Old 04-28-2004, 01:39 PM   #21
Car: JBP 04 WRX STi
Originally Posted by M.S.P.T
i spoke to my local scca region and i would be in asp.
dave
ASP -- that's interesting. Are we talking about an otherwise SM car that is bumped to ASP? Just out of curiousity, which region are you running with?
Rick...
rkremer is offline   Reply With Quote
