Old 03-07-2007, 12:54 PM   #1
Car: 06 STI White with Go
Fav Mod: JDM Mesh Grill
IWSTI Addict since: Nov 2006
Default Lug Nut Help
I have a 06 stock with the stock BBS wheels on it. MY buddy just got me a set of black BBS lugs for me but when I look at the lugs the part of the lug that goes against the wheel is not flat. Will these lugs work on my car or am I missing some thing.
moreda_5 is offline   Reply With Quote
Old 03-07-2007, 01:07 PM   #2
Moderator
Car: 05 Ram 3500 CTD
Fav Mod: Majin
IWSTI Addict since: Apr 2006
What do you mean by not flat? Rounded? Pics would help, but it sounds like they probably wont work...
Old 03-07-2007, 01:09 PM   #3
They look like this on the end.
Old 03-07-2007, 01:13 PM   #4
Spiteful Old Codger
IWSTI Addict since: Jul 2003
Your picture shows a flat-taper (aka 'tuner') lug. Yes, that will work.
The common problem is actually the reverse, when people try to fit convex OE lugs to the flat-taper seats.
(_) VS \_/
Old 03-07-2007, 01:22 PM   #5
cool
i was worried because the stock sti bbs wheel look like they have a flat surface on them.
Old 03-07-2007, 01:32 PM   #6
Muller Chevrolet
Fav Mod: a new 09 STi
IWSTI Addict since: Oct 2004
i think they'll work, however the stock lugs are meant for the bbs rims.
VSGTS14 is online now   Reply With Quote
Old 03-07-2007, 01:37 PM   #7
Spiteful Old Codger
If you look closely at the OE seats, you'll see that they have a flat chamfer which will mate properly to the pitch of the tapered lug.
The OE seat's chamfer will also work with a convex lug (like the OE), because it's relatively short, it's hardened (a steel seat) and the OE wheel is lug-centric.
The common problem is when people want to use an all-alumium wheel (no lug seats) with a full-taper seat and the wrong center bore. Then you have a lug-centric wheel, but the convex lugs only bear along tangents in the tapered seats. That's when you *need* tapered lugs. Of course you should still use the correct center bore as well.
...of course make sure your BBS lugs have the correct thread pitch.
Old 03-07-2007, 01:39 PM   #8
Spiteful Old Codger
In this situation, the OE lugs don't fit any better than tapered lugs.
Old 03-07-2007, 01:45 PM   #9
Hey guys thanks alot for all the help.
Old 03-07-2007, 06:44 PM   #10
Default Lugs are on
Lugs are on thanks for the helps guys
Old 03-07-2007, 08:17 PM   #11
Car: 05 PSM STi
Where did he get those lugs?
btw, your photo looks like it was taken somewhere around the cheleno valley/tomales area
dobie0791 is offline   Reply With Quote
Old 03-08-2007, 07:00 AM   #12
My friend got them from me from BBS that actually say BBS on the top of them.
You are right that is the road the road that brings you back into Petaluma from the coast. It was taken on the first drive we all did.
are you in norcal?
Old 03-09-2007, 06:59 PM   #13
Car: 05 PSM STi
I'm from Santa Rosa- Bennett Valley.
